Here in sweden they are called ölkorv (beer sausage)
Attaching one to my son's frame fueled him for an epic 9km shred this weekend.
Recommended 👍
[url= https://i.ibb.co/Lv4GLvZ/20210508-155649.jp g" target="_blank">https://i.ibb.co/Lv4GLvZ/20210508-155649.jp g"/> [/img][/url]
Maybe tape it in a different place. Not sure I'd want to look down and see that between my legs!
Under side of the top tube may be a better position, the environmental protection sleeve looks good.
Could possibly have a double barrel option for banana pudding.
Will it work for Cheesestrings?
Could you not slide a couple into your handlebars?
I suppose that's not a tool free solution though.
Have a look at the backcountry research super 8. it'd be perfect for those!
Get yourself some of these (or similar) to save using tape: https://www.amazon.co.uk/Straps-Reusable-Cable-Organisers-300mm/dp/B07XD28VG4/ref=asc_df_B07XD28VG4/
I reckon you could utilize the space under the nose of the saddle. Fix it by one end so it dangles down. The air will keep it refrigerated.
Can you not curl it out around the waterbottle and secure with tape?
like the idea of inserting in the handlebars. could fashion some tyre inserts out of them too. Slight concern about bears in the area but should be OK
No pudding 😉
