Pedals! shimano or ...
[Closed] Pedals! shimano or time?
[#652156]
dumping the Mallets and Candy's, fed up of bending/breaking the springs and axles
which should I change to? I need three sets so it needs to be right
heavy rider so needs to be robust, ride all year so mud clearance/ tolerance is an issue. I want decent float and good retention etc etc
looking at one pair of fat DH style for the SS, 2 pairs of "normal XC"
what models and where to buy at the moment?
Your thoughts?
Posted : 22/06/2009 12:24 pm
Time. I had Shimano years ago, broke them. Time ATAC's seem to be pretty indestructible.
Posted : 22/06/2009 12:27 pm
Another vote for Time here. Tough as old boots.
Posted : 22/06/2009 12:36 pm
The only concern with Time is that the old ones i used 10 years ago the bearing used to seize and then the pedal would unscrew
Posted : 22/06/2009 12:43 pm
Time, got 3 sets,no problems ever
Posted : 22/06/2009 12:59 pm
yup, had Time pedals for years. Zero maintenance, zero problems.
Posted : 22/06/2009 1:04 pm
I would say shimano.... only pedals i use - easy to service and seem to last ages riding in lakes / peaks
my 2ps worth !
paul
Posted : 22/06/2009 1:25 pm
My Time Z Controls are now on their third bike in 7 years. I did bend one axle hitting a rock, but replaced with one from an even older Alium.
Atac carbons on the race bike.
If you're used to Crank Bros, Time are very similar. I used Time for a few years, then Eggbeaters when they first came out, then back to time when the Eggies kept falling apart.
Time pedals are very tough - good old-fashioned fit and forget components.
Posted : 22/06/2009 1:31 pm
Time every time...
[i]If you're used to Crank Bros, Time are very similar[/i]
Except they don't break in the middle of no-where, and the importer don't talk down to you, telling you that you didn't complete the required maintenance.
Posted : 22/06/2009 1:34 pm
Time here too !
Posted : 22/06/2009 1:36 pm
Used Shimano pretty much exclusively in the last 10 years.
Dabbled with Look when they first came out and then a set of Ritchey Logics. The looks broke a spring and the Ritcheys got a bit rough.
Had various Shimano since then, 505s, 540s and 770s and never had an issue. The 505s are nearly 6 years old and used every daily on my hack bike. Grease them up twice a year and thats it.
No experience of Time, but im not looking to change from Shimano anytime soon. Im 17st so if they were weak i would have found out by now!
Posted : 22/06/2009 1:53 pm
