Pedal Slip Problem
[Closed] Pedal Slip Problem
[#6001420]
When trying to pedal sometimes I'm loosing about half a pedal stroke before before I can get any resistance and drive forward assume its rear free hub problem ? I run Hope Pro 2 rear hub could it be a problem with the paws engaging
Posted : 01/03/2014 9:31 pm
Yup, definitely- luckily it's nice and easy to check, there's a wee bit more to it than this but it is basically pull the freehub off, have a gander.
Posted : 01/03/2014 10:11 pm
Thanks Northwind do you think I will need new paws
Posted : 01/03/2014 10:22 pm
pawls btw 🙂 Most likely the springs, but it might just be dirty- pro 2 sealing is pretty poor so crap can get into the ratchet ring and just clog it up.
Posted : 01/03/2014 10:26 pm
Posted : 01/03/2014 10:34 pm
Thanks guys it was full of crap and one of the springs was stuck down all sorted
Posted : 02/03/2014 11:31 pm
