Pedal pins
[Closed] Pedal pins
[#11160553]
I'm trying to find a source for some black M4x8 socket cap pedal pins, with the unthreaded end section, without having to buy a full set from Superstar for £20 which will include (yet another) set of the M4x10 that I don't need.
Can't seem to find any though?
Posted : 26/04/2020 5:18 pm
I bought some of these the other day, quite impressed with the grip so far:
https://www.ebay.co.uk/itm/303530043421
The same seller also does some that have an Allen head.
Posted : 26/04/2020 11:21 pm
Buy yourself a bunch of standard Allen head M4x8 screws, dirt cheap.
Stick the screw head first in a hand drill, and together with a file use that as an improvised lathe to remove the threads at the tip.
Alternatively, just use those as they come, threaded all the way to the end. You might even find them either grippier that way, more durable of kinder to your soles
Posted : 27/04/2020 3:13 pm
Cheers for the suggestions. Messaged Superstar and they've sorted out an order for just the short pins, so all good.
Posted : 27/04/2020 4:41 pm
