Panaracer Razer XC ...
[Closed] Panaracer Razer XC 2.1 - rolling circumference?
Anyone know the rolling circumference of these tyres - would save me some time tonight setting my computer.
Posted : 17/06/2010 1:51 pm
Depends on how much pressure is in your tyres.
Posted : 17/06/2010 1:52 pm
just get a big tape measure ? or string then measure it - thats what I'd do ๐Ÿ™‚
Best method: Arrange bike so tyre valve is at bottom. Place marker on floor. Sit on bike. Waddle/pedal forwards until one wheel revolution completed. Mark where tyre valve is on floor. Measure between two points.
Posted : 17/06/2010 1:55 pm
Or you could measure the diameter of the wheel with the inflated type on it and do:
Pi x diameter to find the circumference.
Pi = 3.14
[url= http://math.about.com/library/blcirclecalculator.htm ]Or just whack the diameter or radius into this[/url]
Posted : 17/06/2010 2:02 pm
But the rolling diameter of a vertically loaded tyre is not the same as an unloaded tyre...
Posted : 17/06/2010 2:04 pm
๐Ÿ˜›
Posted : 17/06/2010 2:08 pm
It'll make such a minute difference that it doesn't really matter?
2068 is what I tend to use for 26x2.1 tyres, which IIRC is what Cateye used to recommend.
If it's infact 2075mm that's 0.3% difference, so when you think your ride was 25 miles, it was actually 25.075 miles!
Posted : 17/06/2010 2:28 pm
poppa - Member
But there has to be some (likely insignificant) slippage Shirley?
Posted : 17/06/2010 2:33 pm
If you are happy with an 0.3% error in your distance reading then fine, but some of us hold ourselves to higher standards. ๐Ÿ˜†
Posted : 17/06/2010 2:41 pm
Just concentrate on riding faster. If you think you're going slower than you really are it should spur you on! Think of it as a training aid.
Posted : 17/06/2010 3:09 pm
2075mm at 36psi for me
Posted : 17/06/2010 10:06 pm
