Orange P7 (2008 mod...
[Closed] Orange P7 (2008 model) dropouts slipping/coming loose - solution?
[#6371984]
I recently purchased a 2008 Orange P7 with the slidey 2-bolt replaceable dropouts. They seem to work their way loose every 2-3 rides. I think it may be partly related to hard braking. Has anyone found a solution to this problem?
Thanks.
Posted : 29/07/2014 3:12 pm
Tired threads?
Posted : 29/07/2014 3:14 pm
They seem pretty good to me.
A friend of mine who is a mechanic said that he once had the same problem and resolved it through roughening up the the surfaces in contact with one another with sandpaper.
Is this advisable?
Posted : 29/07/2014 3:43 pm
[url= http://www.halfords.com/motoring/paints-body-repairs/car-tape-glue-velcro/loctite-threadlocker ]Loctite threadlock[/url]
Posted : 29/07/2014 3:51 pm
Orange used to do a modified drop out to solve this exact problem. Its a bit of a crummy design to be honest I've seen 3 frames of this era and they all suffer. The previous owner would have known about this I am convinced..
Posted : 29/07/2014 3:59 pm
This is the LH drop out [url= http://www.orangebikes.co.uk/shop/components/dropout_and_derailleur_hangers/p7-08-lh7_5mm-P596SPA ]orange website[/url] and [url= http://www.orangebikes.co.uk/shop/components/dropout_and_derailleur_hangers/p7-08-rh-7_5mm-P595SPA ]this[/url] is the RH drop out. The LH one pictured below has a third bolt which goes into either a mudguard mount hole or maybe you have to drill a hole I can't remember, it was 2009..
Make sure it comes with the steel plates that squish in the slot where the drop out slots in as that makes a difference. The extra mount hole will make it last a bit longer than 2-3 rides but in my humble experience the prognosis is not good.
I spent a good few hrs trying to help a GF fix hers, even my self proclaimed "genius" husband could not fix it. Its an aluminium alloy drop out on a steel frame, he reckoned it was a crap design..
Posted : 29/07/2014 4:05 pm
I believe that they did a new drop out that used the rack mount hole as a third bolt hole and solved it. Contact Orange, they will tell you which one you need.
They fixed this on later models (from at least 2010, maybe before) by using a 3 bolt design from the start.
Posted : 29/07/2014 4:06 pm
There is a magazine review [url= http://www.bikeradar.com/gear/category/bikes/mountain-bikes/product/review-orange-bikes-p7-pro-08-30569/ ]here[/url] that identifies the problem from back then. I remember orange "confessing" to accidently using the wrong size bolts on the test bike, draw your own conclusions, but when you google [url= https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=orange%20p7%20pro%20drop%20out%20problem ]orange p7 pro drop out problem[/url] you get a fair few hits...
Posted : 29/07/2014 4:15 pm
I had this problem on mine, Orange sent me the new 3 bolt dropouts free, they are also a bit thicker. Fitted them and its never been a problem since. I also made sure the dropouts were fully forward so sliding forward was impossible, made the design redundant but works. I also used a torque wrench to fit them as there is a temptation to overtighten and strip the threads.
It wasn't Oranges finest piece of design but like I say its been fine for five years now. Do it then enjoy your bike.
Posted : 29/07/2014 5:01 pm
