Just ordered some new brakes for my Five. Will it be possible for me to install the rear brake through the chainstay without having to bleed the brake?
Would pulling out the hose from the lever and feeding it through back to front then attaching back to lever work??
No, this will not work, and yes, you will need to bleed your brakes, simple answer!
When i did mine, the brake worked perfectly after, no bleeding required!
Feeding the hose through the frame was a right ball ache though
shitmanos didnt need bleeding after i did the same for mine.
avids did need bleeding on my 224 though, prob just unlucky tho.
give it a go anyway, bleeding brakes isn't hard!
They are shimano brakes so hopefully this will work.
Any tips from the people who have done this successfully? What's the best way to get the hose through the chainstay?
Thanks
Anyone?
As with all these things a guide is needed to make it easy, coat hanger or cable outer etc. pull it through with the old one and use that to pull the next one through. Make sure you have the stuff to do a bleed though as it could go all wrong.
Coat hanger worked for me (taped to the brake hose). A bit fiddly and I needed to bleed the brakes after.
Does anyone know will the olive need cut off for new style shimano brakes or will the whole lot fit through the holes in the swingarm?
I am wondering this as well Tony.
I currently just have it cable tied to the swingarm, but I feel it's a tad exposed
Generally, the hose will need shortening, and very doubtful you'll get a compression nut through the holes anyway, so trim it off. It's usually much easier feeding it front to back, but if you have a crimped on banjo at the caliper, then it'll have to go in from the rear. Feed a gear inner through from the front, fish it out, feed it into the open hose, and use it as a guide to feed the hose through. Removing the rubber grommet makes feeding through much easier, but refitting it with the hose in place isn't a nice job (easier with smaller hose like yours though). Don't forget to feed it through the shock mount before reconnection too, or you'll have to pop the shock out as well 😳
My XT's didn't need bleeding and I used a spare spoke to attach to the hose in order to feed it through. The rubber grommet is a right b1tch to fit back into place though! Olive will need replacing when the hose is shortened.
I used the coathanger method to feed the hose through. Reused the olive and didn't need to bleed afterwards. Hope M4 brakes.
My dilemma is the fact the hose doesn't need shortened, but buy he sounds of it the compression but ain't gonna fit
