Orange Alpine - Ver...
[Closed] Orange Alpine - Vertical Play in Rear Shock
[#5114698]
There's a tiny bit of vertical play in the swingarm of my 2011 Alpine 160. I can't find the definitive answer online but I think I've narrowed it down to the rear set of shock mount bolts.
Can anyone confirm this and if so, do I just need to replace the bolts and central sleeve with [url= http://www.orangebikes.co.uk/components/#bolts ]these[/url] from the orange website?
Thanks in advance!
Posted : 29/04/2013 9:29 pm
I've had similar play on my Five before. First time it happened was play in the lower shock bushing. Second time was one of the pivot bearings falling apart! I would remove shock and check swing arm pivot first to eliminate that.
Posted : 29/04/2013 9:42 pm
 bigh
Mine creaks like hell when the pivot bearings need replacing (waits for the usual filing cabinet/bag of spanners jokes). So if there's no creak its probably the shock bush. 🙂
Posted : 29/04/2013 9:49 pm
Thanks Nicksee. I'm pretty sure it's not the pivot bearings as there's no lateral play but I will remove the shock and check if the swing arm moves freely (in the right direction).
I'm assuming there is a difference between a shock bushing and the shock bolt and central sleeve available from orange and it could be either of those two? Am I correct?
Posted : 29/04/2013 9:51 pm
Yes, the shock bolt goes through a replaceable bushing in the lower eyelet of the shock. Much more likely to wear than the bolt. Not easy to fit without the tool though. [url= http://www.tftunedshox.com/Miscellaneous/Mount-Kits-and-Bushings/Eyelet-Bushings ]bushings[/url]
Posted : 29/04/2013 9:58 pm
 bigh
You'll most likely just need a new bush (shaped like a hula hoop) which sits in the eyelet of the shock. The bolts rarely need replacing. Try http://www.mountainbikecomponents.co.uk/ as well as direct from Orange. They can also sell you a useful tool to help replace the bush
Posted : 29/04/2013 10:00 pm
