Looking at getting an Orange 5 frame for a self build - Would like to use existing forks, that have a 205mm steerer tube. Can anyone tell me if they'll fit with a bit of room for spacers?
120mm headtube on 16" and 18" so you should be fine
All the geometry figures are on the Orange website
120mm!, phew that's a relief.
p.s. ta for website reminder (doh!)
remember headset, spacers, stem etc etc. I have an 18 inch 5 and the forks are beside me at the moment in a box to go to Mojo tomorrow - I have just measured the steerer at 204mm. I am swopping around headsets and will be cutting about 3mm off the steerer to run with an FSA XL2, 15mm of spacers beneath the stem, a Thomson X4 and no spacers above.
Thanks for the info. Blimey, talk about great minds think alike! I'm planning to use an XL2 headset & Thomson stem. If poss. would like to 20mm's worth of 5mm spacers to play around with bar height.
Just for info., what stem length/rise are you running?
bowglie - I recently changed from the Orange stalk stem (80mm, 7 deg)and in house bars to a 90mm 10 degree rise Thomson X4 stem and EA 70 bars. I have ridden it a few times since the change and the front end is a good bit stiffer and with slightly wider bars more comfortable. I am expecting to have the steerer at 200/201mm once I have reset it all - I have ridden it with 15mm of spacers beneath and 10mm on top for a while so know that the 15 mm is right. I think you will be able to get the same setup without touching the steerer, as it sits about 6mm down in my 10mm spacer above the stem. hope this helps -)
Hmm...interesting (esp. what you say about increase in stiffness with new stem) It sounds like my bike build might not be such a haphazard cobbled together mess as I first anticipated. Had a rummage in my parts bin and have got a 90mm, 5 deg Thomson & EA70 mid-rise bars that are original full length. Once again, ta for the info.
Hmm..nice comparison between frame colours.
GaryLake - are those Fox Vanillas on your bike? (if so, do you find they suit the bike OK?)
