Orange 5 shock size...
[Closed] Orange 5 shock size.
[#4819947]
Hello all, quick question for you. Is the bargain 190mm 51mm RP23 at CRC the right size for my 5? I thought it was 190mm 50mm but am unsure is the 1mm makes a difference as I'm not the sharpest when it comes to such things.
Thanks in advance.
Posted : 31/01/2013 4:14 pm
It will fit fine and will equate to roughly 3mm more travel
Posted : 31/01/2013 4:52 pm
 LoCo
they'll be the same shock length, just people round up or down on the 2" stroke when converting to mm 😉
Posted : 31/01/2013 4:53 pm
Cheers chaps. I've been told a medium/medium shock is the correct tune for a 5. Is this right?
Posted : 31/01/2013 4:57 pm
 LoCo
Yes that should be ok, if it's got a High volume aircan, it's worth fitting a small or medium air volume spacer to help with the spring progression in the mid and end of stroke.
Posted : 31/01/2013 4:59 pm
Thanks LoCo 😀
Posted : 31/01/2013 5:13 pm
