orange 5 eye to eye
[Closed] orange 5 eye to eye
[#2451131]
and stroke length
i would like to fit a coil to my orange 5 but want to check the stroke and the eye to eye
i have tried searching but had no luck
Posted : 08/02/2011 10:08 pm
 LoCo
190 X 50 mm 😀
p.s what lathe/s do you have?
I don't suppose you know how to get the shock out of the 5 frame do you? I've undone the bolts but the threaded part seems to be stuck.... itching to replace my old swinger with an RP23..
Posted : 08/02/2011 10:13 pm
 LoCo
Drift, or smaller long bolt to tap it through carefully.
Posted : 08/02/2011 10:14 pm
i have loads at work none at home mond you this would be a bus mans holiday
what happen if i ran a DHX 200mm 2.25" would it be ok if i ran it with sag?
bingo !, thinking of trying a coil myself just for the hell of it. local route includes some fast rocky lightweight DH, vanillas up front are far better than the floats i had so im thinking that a coil at the back will improve the ride compared to a rp23,,,, is this reet ?. couldnt give a **** about the extra weight
anybody used or recommend a coil for the 5 and maybe include the pros and cons of using one.
cheers.
Posted : 08/02/2011 10:15 pm
 LoCo
Swingarm may touch the seattube on full extension.
Posted : 08/02/2011 10:16 pm
bugger i can not find a 190 coil shock but i am blind when it comes to these things.
did you need some machining doing
Posted : 08/02/2011 10:18 pm
 LoCo
No just lathe geekery 😀
Well unless you have some CNC ones for some piston manufacture...
Posted : 08/02/2011 10:20 pm
sorry spam. 😳
i have a brand new 2011 fox rc 190x50 will be in the classifieds tomorrow
Posted : 08/02/2011 10:26 pm
cool how much would like?
what spring is on it?
Posted : 08/02/2011 10:27 pm
i'd like £160 posted
600 fox spring or i have a 450 cane creek.
22mm x 8mm bushings
Posted : 08/02/2011 10:36 pm
how much for the CC providing its a 190x50 ?
Posted : 08/02/2011 10:38 pm
LoCo - Member
How would this happen? Surely if the eye to eye of the shock is the same then there shouldn't be a problem? 🙂
Posted : 08/02/2011 10:41 pm
i may well be interested in the shock can i have some pictures when you get a minute heavy spring please !!!!!!!!!!!!!
larrythelathe at hotmail dot com
Posted : 08/02/2011 10:50 pm
oreetmon - Member
spring is 450x2 (no shock) £10 + postage, if larry doesn't need it.
Posted : 08/02/2011 10:51 pm
sorry, miss read post.
im keen at 160. need to know asap
Posted : 08/02/2011 10:52 pm
more spam, sorry,
pastcaring : what's the reasoning behind selling the van rc? I'm considering one for my 5 but if they aren't much cop I'll reconsider
Posted : 08/02/2011 10:54 pm
larrys your man, just 'phoned a friend' and have a mates rates bargain.
thanx anyway. 😉
Posted : 08/02/2011 10:57 pm
still interested in opinions on putting a van coil on the back of a five if anybody has the experiance of one ??????
Posted : 08/02/2011 11:07 pm
 LoCo
Hugh b, the standard shock is 190mm eye to eye the 200mm is 10mm longer 😀
Posted : 08/02/2011 11:10 pm
I run an old vanilla rc in the back of my five. Transformed the bike compared to the old swinger 3way that was utter garbage.
Posted : 08/02/2011 11:13 pm
 LoCo
Van rc is good, but are really good when tuned as basic valving is exactly that.
Waiting on DSP Duelers to come through in 190mm and 200mm lengths but not due till end of April earliest 👿
Posted : 08/02/2011 11:14 pm
I keep thinking about swapping my year old rp23 bv for a coil, anyone?
Posted : 08/02/2011 11:15 pm
ORANGE 5, COIL SHOCK
YAY OR NAY ????
wat is this dsp malarky ?
Posted : 08/02/2011 11:17 pm
Ah sorry LoCo, I miss read!
Thanks
Hugh
Posted : 08/02/2011 11:20 pm
larry ygm
oreetmon, I will be receiving a 2011 van rc this week for my 2010 five. I'll let you know how it goes this weekend.
Hugh
Posted : 08/02/2011 11:21 pm
 LoCo
Diverse suspension products, have a look at the site, not going to post links to my website as thats proper astro 😀
Posted : 08/02/2011 11:22 pm
hugo, loco.
nice 1
will keep an eye out for you commnets
good night yall
Posted : 08/02/2011 11:27 pm
tomat0 - Member
more spam, sorry,
i got it for a little experiment (turner 5spot), that didn't work out, so never tried it.
Under intrest i have been using an Manitou IX6 for a couple of years and transformed the 5
and a lot lighter But looking to try the ELKER 5 Stage as can't be faffed in the lengthy set up
of the Cane Creek
Posted : 08/02/2011 11:28 pm
Those dsp ones look awesome
A MATE OF MINE RUNS A DHX ON HIS FIVE HE LOVES IT ;O
Posted : 08/02/2011 11:31 pm
grantway - Member
of the Cane Creek
i'd like to try an elka...
not to much ****ing about with the ccdb. base settings from cc, then a couple of clicks each way byu
also had a avalanche shock on a couple of frames also very good
Posted : 08/02/2011 11:37 pm
