Has anyone got one? What size and where from. I am struggling to find anyone with anything suitable in stock.
Thanks
Jim
If you have an older 5 then it's a Gravity Dropper or X-Fusion Hi-Lo for you. If a newer (2011?) model then take your pick from all the usual suspects.
Is that what you meant?
yep its the older one with 30.8 mm post.
I think KS fits as well but none in UK
Have you any experience of either of those posts?
Is it not a 27.2 post for the older five, but perhaps 30.8 clamp?
Anyway, I have a gravity dropper on my five, it's ace. Agricultural in looks and functionality, but reliable and doing the job very well. Dead simple to disassemble and clean as and when required.
A mate has the same setup and would tell you a similiar story.
old up to this year iirc are all 27.2 in which case a GD
IF you have the larger verison then you need to get a GD and a shim 😀
I've got my 2008 5 fitted with a KSi7, works a treat
helps if you know the diameter of your seatpost, not the seatpost clamp... As others have said it will be 27.2. Orange have gone to 30.9 for newer frames to accept more uppydownies.
Choices are
gravity dropper- out of stock,
KSi7- out of stock,
and Xfusion Hilo. Available from continent, but now has UK importer.
review of hilo here
http://www.singletrackworld.com/forum/topic/x-fusion-hilo-272-review
and a google search should show up a scan of an MBR group test (though they seem to have got a duff GD as theirs had loads of play and they hated it).
PS I have a GD on my 27.2 posted Orange Alpine.
