Ooh a 'what fr...
[Closed] Ooh a 'what frame would you recommend me' thread!
[#4827573]
It could be either a short travel full suss or a hadtail. The objective is to get a light second bike (the other one weighs a shade over 30lbs).
It must have:
- A head tube that can take a tapered fork
- 135mm by 12mm rear
- Built around a 140mm fork
- Not be a cross country bike
Budget is around £1200.
Posted : 02/02/2013 9:40 pm
Transition bandit - last years model should/could be found for around half that unless you looking at a whole bike?
Posted : 02/02/2013 9:42 pm
No just frame and I don't have to spend that much, it's an 'up to' figure.
How much does the bandit weigh?
Posted : 02/02/2013 9:46 pm
Bandit is on the heavy side but it looks nice enough. It also looks to have a 142mm by 12mm rear or 135mm by 10mm.
Posted : 02/02/2013 9:48 pm
An old Cannondale prophet mx
Posted : 02/02/2013 9:49 pm
Yeti ASR5?
Posted : 02/02/2013 9:53 pm
Two excellent suggestions. Thanks. I recall the Prophet MX being highly recommended by Dirt.
Hardtail suggestions?
Posted : 02/02/2013 9:54 pm
Argon cc
Posted : 02/02/2013 9:57 pm
Getting a light second bike is easy. The harder part is gettig said bike that's right for what you want it for. DH, XC, Freeride, enduro etc. or all of the above..?
Posted : 02/02/2013 9:58 pm
Its a good point symbian. Put it this way, if the Cotic Soul had a 12mm rear axle I would have one of those.
I need the 12mm rear because I want to use one set of wheels between two bikes.
Posted : 02/02/2013 10:01 pm
If you've got a full sus, I cant see the point in a hardtail with long forks. It'll ride just the same but not as well.
Posted : 02/02/2013 10:06 pm
David that's true, but I need something that will require me to ride a bit slower. It's time to slow down a bit.
Posted : 02/02/2013 10:09 pm
If your budget is £1200, why not get a shorter forked light hardtail with some lighter wheels within budget?
New SC chameleon will probably be light, looks like they've slackened the HA so it'll be good with short forks if you want a slack HA.
Posted : 02/02/2013 10:12 pm
It's the wheels that I really want to use betwen both bikes but I like your thinking. Will investigate the Chameleon.
Posted : 02/02/2013 10:18 pm
you could always use a 12->10mm step-down axle and broaden your frame options...
Posted : 02/02/2013 10:22 pm
How about the NS Surge. 10mm axle though. I have a 12mm axle atm & will just need to get a 10mm axle.
Super versatile frame with long or short forks, adjustable dropouts etc. short chainstays a la Stanton Slackline, Slack HA a la Pig X.
Posted : 02/02/2013 10:34 pm
or this..
http://tinyurl.com/b8j6c3g
Frame £559 @ Zulu bikes
Posted : 02/02/2013 10:51 pm
Tymnian I love that Privee Shan. Do you know if it has a 12mm rear?
Posted : 02/02/2013 10:59 pm
140mm is not short travel, for me a blur LT would be a good choice if you can find a taper headtube frame as I dont think they did them before late 2011
Edit not 135x12
Posted : 02/02/2013 11:03 pm
http://www.production-privee.com/PBSCProduct.asp?ItmID=11265930
has Rear hangers: removable designed and provided with 135x10mm, options: 135x12 and singlespeed (40€ per kit)
its a beautiful bike, I wouldn´t say no
Posted : 02/02/2013 11:04 pm
Only needs to be a 140mm fork not necessarily a 140mm rear travel, e.g. The Blur TR.
Instead of restricting your options on rear maxles- which is quite a big deal- I'd do as suggested and sleeve the wheel down so you can use it with a 10mm. A little heavier but it'll pay off.
davidtaylforth - Member
Nope.
Posted : 02/02/2013 11:06 pm
New Chameleon looks nice! 4.7lbs and they're claiming 68 HA @ 491 A-C (that's 120mm Float 32 static) but it looks slacker in the pictures.
Posted : 02/02/2013 11:10 pm
Santa Cruz: Making alu hardtails that weigh more than steel ones since 1993 :mrgreen: Bet it rides well though.
Posted : 03/02/2013 12:00 am
It's a pound lighter than the old one though!
Just the same as a Blur LT but not as well, so I hear... 😉
Posted : 03/02/2013 12:19 am
I was so hoping the Ragley Troof I had was going to be my equivalent of what I think your after... but unfortunatley the frame cracked after less than six months (before I had even bought the 135x12 dropouts... luckily!).
I'm still looking for the same - I want it to take all the parts from my Nicolai; dropouts to take 135x12, full 1.5" headtube, 31.6 seatpost, ISCG... and be singlespeedable... and light.
I'm currently running a little Mmmbop as my hardtail and it does some of these pretty well. Although I would change it tomorrow if I find something else.
To run the 135x12 wheels in it I usualy change the (Hope) end caps but I also have an axle like this [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=65450 ]135mm Axle at CRC[/url]. It's handy for trueing wheels as it's a straight shove in quickly and go ride/fix. Mine is made by Nukeproof from parts of the Forth Rail Bridge so I tend not to take it out on the trail.
The only way I can see to tick all the boxes is custom; Chinese Ti, Nicolai Argon AM, BTR Ranger etc... but as it's my second bike I'm not that bothered (until I break the Mmmbop 🙄 ).
Posted : 04/02/2013 9:02 am
Hey Messiah good to hear from you.
One of the interesting insights from this thread are these step down axles. I wasn't previously aware these were available and it looks like this is just the thing I need.
Being able to swap the wheels between bikes is a big bonus as a)they are really nice wheels and b)it costs less. I'd rather have one really nice set of wheels used between new bikes than two sets of mediocre ones.
The Argon AM is what I've been thinking of but they are soooo expensive and I've always said that hard tail Nic's don't really make much sense when there are so many other great hard tails out there, made out of steel. The Argon FR I tested several times was pretty damn good though. Easily as good as the best hardcore steel hardtails I've tried.
If you broke the Ragley didn't you just get a replacement?
Posted : 04/02/2013 9:42 am
 jedi
transition double.
bandit is more "xc"
or pivot bikes 4x
Posted : 04/02/2013 9:46 am
Blur TR (or c)
Posted : 04/02/2013 10:03 am
Hi Geetee.
The Troof was near perfect but no more frames were available so I went for a refund.
Argon FR's have dated geometry so for me they are out. The AM is tempting but the cost is high and although I like the little alu Mmmbop I'm not sure I want a harsher frame... weight's I have seen for the FR and AM are all over 5lbs which is a lot of material for an Alu hardtail!!! Good enough for Shneidi in the Mega though 😯
Have you considered doing a [url= http://www.spanner.org.uk/ ]Spanner Bikes[/url] and getting a Ti hardtail frame to your own specifications? I'm thinking it might be the way to go for me as I know what I want but nobody is building it... although the new on-one 456 Ti would perhaps have tempted me if it could take a 1.5" steerer and 31.6 seatpost.
Posted : 04/02/2013 10:28 am
Will the 2013 Nukeproofs still have a 135x12 rear end?
If so, the TR version (130mm rear?) would be a good choice.
If they're good enough for Sam Hill...
Posted : 04/02/2013 10:43 am
good enough for Sam Hill [b]to be paid to ride them[/b]...
Posted : 04/02/2013 11:18 am
How about a BTR Ranger with custom dropouts?
Posted : 04/02/2013 12:28 pm
Those axle things do work well. Use it quite a bit when I want to put my beefy wheels on the hardtail. If I'm doing that then I'm generally not bothered about the extra weight!
Edit: oh and regarding the what frame question, if I did have to replace my mmmbop I'd be having a good look at the new chameleon. Quite like the look of the Trans Am too. Though I think both fall foul of your axle requirement.
Posted : 04/02/2013 1:07 pm
How about getting 18 bikes to build a custom steel frame based on soul geometry? Or even buy a soul and have them or somebody else put new dropouts on it?
Posted : 04/02/2013 1:31 pm
I Ache - I was on the phone to them this morning 😀 Great suggestion.
It looks like the step down axle is the perfect solution which open up all the great steel hard tails out there.
Thanks all for the suggestions.
Posted : 04/02/2013 2:12 pm
I was speaking to [url= http://www.kingdombike.com/ ]Kingdom Bike[/url] about my requirements and they send me diagram of a good looking 650b prototype a bit like the Brigante...
Which had almost all the bells and whistles I wanted, and all the lessons they learned from overbuilding this prototype.
I've asked him for a 26er version but Chris has been very busy of late redesigning the website and other stuff.
Posted : 04/02/2013 3:12 pm
Mythic rampant - thats what i ride round our hills...
Freeborn bargain at the moment. all requirements apart from maxle back end. dont need that in surrey anyhow, the chainstays are ribbed so its pretty stiff .
[url] http://www.freeborn.co.uk/mythic-2012-rampant-frame [/url]
It really is a great little bike. pedals great, supple (I had the shock pushed by tf) and feels more than 100mm in the bigger stuff.
can run full length post so fine for XC duties.
Involving enough as doesn't steamroller the trails like longer travel bikes but still keeps you in there for KOMs 😉
Posted : 04/02/2013 3:44 pm
I Ache - I was on the phone to them this morning Great suggestion.
Any time. The step down axle looks like a good idea in which case I suggest you just get a Soul. I would suggest you got a BFe, I love mine, but you said you want to take it easy and the BFe encourages the opposite.
Posted : 04/02/2013 5:11 pm
No more KOM attempts for me otherwise I might end up being KIA!
😀 Quite!
I smashed the top part of my humerus last October, three weeks after our second son was born. I just cannot, under any circumstances, afford to have any more accidents (this was not the first. Nor the second. Or the third time. 8O)
Posted : 04/02/2013 6:46 pm
What freeridenick said +1, just picked one up from freeborn myself. Been testing mine out locally over the weekend and its a hoot. I wouldn't fancy any 'hucks to flat'(TM) but 25ft gap/15ft drop to rocky landing was easily dispatched. Running 140 revs on the front at the minute but can dial down for xc/dj.
Posted : 04/02/2013 6:48 pm
yep just to add run sektor coils dual postion so 140mm for descending
110mm for climbing.
under 30lbs with singlering, pro 2s, min ions, sturdy cockpit etc,
Posted : 04/02/2013 7:30 pm
[i]Argon FR's have dated geometry so for me they are out.[/i]
Interesting comment. Care to explain your thoughts a bit more?
Posted : 04/02/2013 9:55 pm
Like many "long travel" hardtail frames of the last 8 years many were designed for 120mm, then okay for 140mm, etc... but just because you CAN fit a long fork does not mean the bike will ride well with one. Whilst the resulting slack head angle from a long fork is a fun thing, the high bottom bracket, high top tube and slack seat angle are not conducive to a great ride (all IMHO & IMHE etc). Better geometry and hence more fun long travel frames are available.
Posted : 04/02/2013 11:08 pm
Cannondale Trigger? Looks like an absolute giggle. No idea if it's available frame only though.
Posted : 04/02/2013 11:28 pm
