Only left side of m...
[Closed] Only left side of my glasses mists up...
 awh
[#3926149]
I'm finding that every time my glasses mist up it's always the left side that mists first, and sometimes only my left side. My 2 theories are airflow around the glasses (my head isn't perfectly symmetrical) or the different side of my brain generate different amounts of heat! Or is it something else?!
Posted : 29/04/2012 9:04 pm
Your head isn't perfectly symmetrical. Give it a good wallop with a rubber mallet, just above your left eyebrow, that should sort it. 😉
Posted : 29/04/2012 9:09 pm
Try putting your glasses on upside down, go for a ride and see if it changes.
Posted : 29/04/2012 9:10 pm
 awh
Maybe I could cover my face in thermocouples to measure its temperature distribution. The only downside I can see is looking like Hellraiser and scaring the ramblers...
Posted : 29/04/2012 9:23 pm
Stoner could help with the spreadsheet for the analysis tho!
Posted : 29/04/2012 9:24 pm
Oi! I resemble that comment!
Posted : 30/04/2012 4:50 pm
try eating only with your right hand, your LHS is clearly fat.
Posted : 30/04/2012 5:07 pm
That happens to me as well, I often wonder why. I wear contacts when I ride. The only thing I could think of was heat and that my left eye is hotter than my right. I can't believe I just typed that.
Posted : 30/04/2012 5:13 pm
 awh
I was wondering that as well! Cheek heat could also be a factor. How is the blooded pumped around our faces?
Posted : 30/04/2012 5:56 pm
your heads are not even, your glasses are.
Posted : 30/04/2012 6:28 pm
I get the same. One side of my motorcycle goggles steams up first. I bet we have slightly assymetric faces
Posted : 30/04/2012 6:37 pm
I get it too, usually when I have just one nostril blocked.
Posted : 30/04/2012 6:52 pm
Use Fogtech, it's the only stuff that does what it says on the tin...sorry for not coming up with anything funny.
http://www.fogtech.com/fogtech.html
Posted : 30/04/2012 7:12 pm
Would you describe yourself as creative and intinctive, or are you logical and methodical?
Posted : 30/04/2012 7:20 pm
