Hiya folks - quick "is this easy/possible?" thread.
I've got an Psylo XC fork, not sure of vintage, but they're in need of a bit of work. Got a bit of oil leakage on one leg so assuming there's a seal on it's way out, plus the U-Turn isn't working so they're permanently at 125mm and therefore a bit twangy. So...
Can I get a seal/service kit from somewhere?
Am I going to regret trying to service them myself if I do?
Is it possible to do away with the U-Turn and just restrict them down to 100mm?
Cheers!
I've seen a few of these, they're pre-2004 but so far as I'm aware you can still get spares for them. TF Tuned are your best port of call:
[url= http://www.tftunedshox.com/ ]Here[/url]
The Psylo has an issue with the compression assembly, which is made of plastic and absorbs some damping oil over time causing it to swell slightly. Last time I checked, TFT will sort this for you as part of the service.
