The on-one merino stuff looks good, and I have an imminent birthday, but I would like to know if the arms come up long or short. I have silly long arms (height 6'2", wingspan 6'7") but usually cope if the arms are long-ish.
Thanks
I've got a xl merino base layer from them, similar sizing to you (6ft 3,long arms), and unfortunately the arms are a bit short. Sizing apart from that isn't too bad.
Feared that would be the case. Many thanks. Only merino that seems to fit me is Embers, may be worth a look.
I'm 6'4", long arms, slim build, and have a zip up cardi and the Element 320g long sleeve top.
Both size L and both fit a treat.
Wear the Element almost permanently 🙂
ooh, the element is the one I really wanted. presume the arms are long enough because of the thumbholes ? I can put up with that...
Have you thought about short sleved base and arm watmers (both merino)? That will be my next buy.
