On One max wheelset
[Closed] On One max wheelset
Hi, I have a set of on one max adaptable maxle wheels, anyone know what bearings needed for a rebuild. Plus anywhere I can download a rebuild information sheet/PDF thanks
Posted : 07/12/2012 7:50 pm
Can't help there, but be interested to know how your freehub is doing. Mines been a right pain, seizing up and needs constant regreasing. Not impressed at all.
Posted : 08/12/2012 11:08 am
My freehub been fine, might be cold\heavy grease issue.
What grease you using?
Posted : 08/12/2012 1:20 pm
Castrol cl. I'm pretty sure its the needle bearings in the freehub as opposed to the axle bearings. Next time it siezes I really need to identify the culprit.
Posted : 08/12/2012 6:00 pm
Had a look at front hub, needs 6805RU bearings, readily available and cheap.
As they where not worn but dry, pried rubber seal off with needle and added a few drops of synthetic chain oil, lot better.
Posted : 10/12/2012 2:11 pm
