Older Orange P7 1x1...
[Closed] Older Orange P7 1x10 questions
My girlfriend has a (currently unused) c2007 SS P7 that I'm thinking of rebuilding for her as a 1x10.
It's got a pair of c2005 Shimano XT M765 wheels that are still going strong.
Does anyone know if they'll take a 10-speed cassette?
I'm thinking of going for a 42t Sunrace one if that makes any difference.
It's also got a rather nice 32t White Industries Eno crankset that I would like to reuse, probably with a chain guide. I was considering using a Superstar Plasma guide with the BB mounted ISCG05 adapter.
Does this sound do-able?
Medium cage XT (Or SLX as funds allow), or would a long cage be a better idea?
Any advice much appreciated ๐Ÿ˜•
Posted : 02/04/2016 3:13 pm
Pretty sure 10sp cassettes use the same hub as 9sp so you should be fine. 8)
Posted : 02/04/2016 3:53 pm
You'll be fine with medium cage if only one ring at the front but you'll need a longer B-tension screw for an slx mech to clear the 42T cog
Posted : 02/04/2016 4:04 pm
Is the chain guide going to be overkill given that it's probably going to be a SS chainring/clutch rear mech?
Most likely use will be trail centre type stuff...
Posted : 03/04/2016 7:01 am
