So, my old Holdsworth, which I currently use in road fixed mode, has an eternally knocking headset.
No matter how tight i do it up (and lock, using the lockring), it's either so tight it binds or instantly develops play.
Any idea? Just a need to replace the ball bearings, or is it all knackered, and I need to track down a suitable 1" replacement.
OMITN
FUBAR, replace.
Are you over tighening the bottom ring and then backing it up onto the top one once that's tight agains't it (it'll make sense if you are)
If not then try that.
timbur - not tried that, but I can do. Lower race is knurled, rather than designed for a spanner.
I assume if it's shot it'll never lose the looseness, will it?
If you can't adjust it properly it sounds wrecked. They normally notch when worn rather than bind, but I don't think there's anything you can do about either.
OK, sounds like a cheapie. Tighten the knurled one up. tighten the locknut up above it and then back the knurled one off holding the locknut one with a headset spanner so it doesn't move. That's how I was taught to do up an old style headset.
Lowest rent 1970s Holdsworth Equipe. Tubes made of gaspipe (lugged, for extra weight). But, the frame was free from a friend, and serves a purpose.
the plan is to make it a SS CX bike for a bit (see other thread on that), so I wanted to resolve the headset issue before going offroad.
No missing washers or somesuch is there?
Not that I can tell.
I think it's just old and knackered. Going to order some new bearings (9/16, I think) and see if that helps settle it down.
Yeah I used to only just tighten mine, then tightening the lock ring would make it good.
I think Velosolo do a nice high chrome 1" headset at a good price.
5/32 is std IIRC, unlikely to help IME
Cheers all. Will have another crack at getting it tight, and then will have to take a view (i.e. if I CBA to put a new 'set in an old shonky bike).
If you replace, remember there are 2 different stds for 1" headsets - 26.4 vs 27.2 crown race.
cheers, al.
Given my limited time availability, this may a LBS job. Need to check out the LBS, tho - it's changed hands since I last went there, when it was described by binners as "like Steptoe's yard".
