Okay so how do I be...
[Closed] Okay so how do I become a better rider???????
This is a good thread, I like how the OP pre-empts all the usual stock replies.
Personally I think my riding has improved more over the last two years than the previous 15 or so, and I put that down to...
Riding with faster people - A big factor, just because it makes me ride faster to keep up.
Skills day - Useful in showing me how to jump and drop properly, although I still lose my bottle too much.
Riding more - Found more people to ride with (partly thanks to STW), most of whom are quicker than me - so I'm sure I've got a little bit fitter.
Riding DH - Going to the Alps and doing some uplift days in the UK, have found this has made me a lot more confident at XC riding.
Practicing the same bit - When I started going to Aston Hill (southern DH venue) I was doing different tracks every time at random, but after meeting another rider there who was riding the same track all day I tried the same thing - and it really worked for me. I could feel my progression throughout the day, which was very satisfying.
I'm still only an average rider and still pretty unfit, but I'm enjoying it and it seems to be working.
Posted : 01/06/2010 11:02 am
like what i got now a 30lbs 6 inch bike.
Maybe having a huge bike with 6 inches of travel is not quite the way forwards!
Something with 4 inches and 5lbs lighter might help you with your fitness as you'll be more inclined to get out and rig-it with guys who you know to be faster and more trail competent.
I wonder, by having this millstone between your thighs is a way of not getting out and practising all that you’ve learnt.
Just one take on it.
You state you like the endurance rides, but a 30lb bike with 6 inches of travel..... I’m struggling to think of a single endurance event that would warrant this sort of bike.
More details please.
Posted : 01/06/2010 11:26 am
Lots of good information on this thread.
2 things which I found really helped me a) get better/faster/confident b) enjoy it more
[u]1: Look where you [b]WANT[/b] to go[/u]
Sounds stupid, but its really not. It was a road ride that taught me this lesson most. I used to find that when going round a corner fast, I couldn't help but drift out to the edge of the road and rough stuff. It even had me off the bike once at speed. Through talking to others I was told to
- bend the inside elbow and drop my shoulder into the corner
- turn my head and shoulders to where I want the bike to be going, and not to look where I think I may end up ( like the verge ).
After doing that, I found I could corner faster and tighter, and since then I've not been drifting out as much. People have already said this on the thread, the wheels do slip a little from time to time, but if you looking where you want to go, for the most part the bike will simply follow.
[u]2: Slow speed technical climbing[/u]
Granny gear stuff over bumpy bumpy things. I used to be absolutely rubbish at it. But by getting out there and practising on the bike, I have become a lot better at it. I now am placing the front wheel where I want it to go, and knowing what to expect when the rear wheel hits bumps etc etc. I find my body moves all over the place and my arms are working hard and it didn't come straight away, but over time my balance has greatly improved and the ability to get up awkward little bits has increased. It means I can make steep climbs without dabbing and stopping and getting frustrated.
Both of these things make rides that bit more enjoyable.
I dont worry about being the fastest. I weight 15.5st and have a heavy full susser. I find finishing the ride having enjoyed it the main thing, not completing it 30seconds faster than the day before.
Posted : 01/06/2010 11:47 am
I think Ton is right... Chill out a bit, why not find some newbies to take out riding, you have been riding a lot for a long time and on plenty of different terrain by the sound of it, maybe your assesment of yourself is out of kilter, and a few nice non life threatening rides out with some beginners will help you re asses where your at.
Posted : 01/06/2010 11:51 am
Do/can you apply what you've learnt on the skills courses to other trails?
Do you go out and practice skills? Even 10 minutes spent popping up and down kerbs helps. A session out in the woods practising corners, or trying different lines across some rooty bits. - using the stuff you've learnt on the courses - forcing yourself to apply what they've taught you - not just falling back into your default "bad habits".
(as you can probably tell), I have a bit of a thing for "body memory". When you learn to do something new or different from normal, you have to do it LOTS until it becomes instinctive to do it that way, rather than in a panicked situation reverting to your old skills.
There's also a large degree of MTFU involved. You currently reside in your comfort zone. To get better (which you want to do), you need to step outside it. The trick is to do it in a controlled environment, and wear armour!
A trick I use, if I'm struggling with something, is to compare it to something near as dammit the same that I can do. A corner is always a cornee - same technique. If I can do *this* jump, then I should be able to do *that* one, as it's only a foot bigger. Think laterally!
...and most of all, believe in yourself! That's the biggest thing!
Posted : 01/06/2010 11:58 am
[url= http://www.superbikeschool.co.uk/technology.php ]LEVEL 2, what it teaches[/url]
This is just how STW used to be, without all the unpleasantness!
If it helps, there's a m/cycle skills company I used to use. Their most popular course was level 2 of 5 levels. Riders each year would re-do level 2, a sort of back to basics and how and where to look course.
Posted : 01/06/2010 12:19 pm
I think the main thing you need to do is work out what you most want to improve on and work on that. Pick a weak point and try and fix that.
I'd second chakaping's suggestion about practising the same bit repeatedly. If you're out on your own get into the habit of noting the bits you think you could ride better and stop and ride them until you work out what you think you're doing wrong. And then ride it using that insight ride it till you think you've improved it. It's ridiculously satisfying to finally get a bit 'right'.
Even bits you do feel happy with have a look at them and see if you can see different ways to ride them and try them. There are bits I've ridden loads of times that after I stopped to think about them I found better lines through.
And if you do crash go back and work out why and see if you can see how you could have avoided it.
When you're out riding with mates then try and work out where it is you loose time to them. Do they take different lines, brake at different points, shift their weight differently?
And then after a while of doing this sort of thing you can always go back to do a skills course with a shopping list of specific things you want to improve which should help you get more out of it.
Posted : 01/06/2010 1:16 pm
Doddy is with MTBR? Shows when I last read a mag !
You appear to have done everything reasonable to try and improve and I would bet you are probably much more accomplished than you think you are. Maybe it's time to accept what you have and just carry on enjoying it - after all you have a very nice bike 😉
Chances are you are merely suffering from post holiday blues.
Posted : 01/06/2010 1:23 pm
The other thing that I don't think anyone's mentioned is to try riding different trails and areas. Personally I reckon part of the reason for my less than amazing skills is that I mainly ride around London (Swinley, North Downs etc), so I don't actually face tricky drop-offs that often, for example.
It's amazing when you do go somewhere new (Afan, Moab, wherever's realistic for you) that you do make the step up in skills as required. And it's when riding all these different types of trail that you apply the skills you've learned etc
Posted : 01/06/2010 1:27 pm
Page 2 / 2
