oil leak on my rev
[Closed] oil leak on my rev
there alays seems to be a bit of oil on my left fork leg by the positive air valve is this normal? i sometimes store the bike upside down
Posted : 25/04/2009 9:11 pm
Seems to be on the right for me.
Posted : 25/04/2009 9:59 pm
From TF Tuned:
"[b]My U-Turn air fork leaks oil from under the U-Turn adjuster cap. What's this?[/b]
This only occurs when the bike is upside-down or on its side, when the lube from the lowers escapes through the top. During service, we fit a modified O-ring to reduce this significantly."
...and...
"[b]Can the leak from the top of my Motion Control be fixed?[/b]
Yes. During service we replace the Motion Control compression assembly seals with the improved, modified version."
Posted : 25/04/2009 10:07 pm
god(tf tuned)can you tell me if its normal for a small amount of oil to spit out of the -ve valve when taking the pump off.cheers.
Posted : 25/04/2009 10:26 pm
From TF Tuned:
"[b]When I alter the negative air pressure in my air fork, there's oil at the valve. How can I stop this[/b]
The oil is lube from the air chamber which collects at the bottom of the fork during use. To prevent the oil weeping, simply tip the fork upside-down before checking/altering the negative air pressure."
I have noticed this happening with my Revs. I've also noticed how said oil tends to spray over the discs when removing the pump...
Posted : 25/04/2009 10:38 pm
cheers god.or are you a decipal.thanks anyway
Posted : 25/04/2009 10:41 pm
 JxL
also happens with my 2009 reba team's. I get a little bit of oil in positive and negative.
Posted : 25/04/2009 11:00 pm
