Had a problem with using a Hope E4 calliper and 180mm disc on RXF 36s. Calliper is directly mounted as RXF has a 180mm post mount.
Struggled to get the calliper set up without it rubbing on the disc, so took it to the local bike shop. They had a look and said that the calliper was fouling the fork leg, and not mounting straight - only solution was to run a bigger 200mm disc and appropriate mount.
Anyone else had this issue?
Posted : 13/07/2017 8:33 pm
