Darkside. Oh no- I ...
[Closed] Darkside. Oh no- I bought the wrong the wrong bike size
 hora
Pain in hands/locked out arms etc. Went into PlanetX to buy a smaller stem and whilst discussing I had a bike fit on a jig and bloke chappy confirmed I should be on a XL not a L as I have a long torso. Originally pre-purchase of the bike I sat on a bike in the shop on rollers and shop said Large looks best.
So, expensive lesson learnt the hardway. 🙁
I should have had a professional/proper bike fit. Would have saved me money.
Posted : 13/06/2014 4:57 pm
Wait, your issue is your bike is too long, so your solution is to get a bigger one?
Posted : 13/06/2014 5:04 pm
Which bike did you buy in large? And what are your measurements?
Surely if the reach is too long on an L, it would be worse on an XL?
 IanW
Lots of riders choose to have smaller frames than the size charts, difference between a large (560) and XLarge (580) could be made up with a stem.
Posted : 13/06/2014 5:05 pm
Why were you buying a shorter stem? For a different bike?
How tall are you?
Agree with IanW, difference in one size can probably be compensated for using a different size stem / different reach bars / adjusting saddle back or forth slightly.
Posted : 13/06/2014 5:10 pm
He said he has a long torso (relatively short legs in other words) which would result in the need for a longer toptube to somebody with a shorter torso/longer legs, and therefore the next size up frame is required.
If your stock stem is short, you may be able to make it up with a longer stem without making it too slow steering. Otherwise wider bars may help too or even a layback seatpost.
Posted : 13/06/2014 5:12 pm
 hora
Its a large pro carbon planet X with a 110mm stem currently. The large is 20mm? lower than the front of the XL. Im 6ft1.7 with 33inside step.
I went in today to buy a 90mm stem
Posted : 13/06/2014 5:25 pm
£600.
Yours,
stumpy torsoed bregante 🙂
Posted : 13/06/2014 5:30 pm
Maybe I'm missing something but if you've got 'locked out' arms on the L, by going bigger the HT might be taller but the TT will be longer. Problem solved how?
Posted : 13/06/2014 5:31 pm
The shop advised L and then subsequently advised XL? Send it back for one that fits
Posted : 13/06/2014 5:32 pm
Sounds like you need a riser stem not a bigger frame (I presume that the suggestion for a XL was for a bigger head tube?)
Posted : 13/06/2014 5:36 pm
Its not like STW has been telling you for years your bikes are too small and now you can do it all over again with the eternal search for the perfect steed with road bikes
Posted : 13/06/2014 5:38 pm
He also said he was getting a [b]shorter stem[/b] so the top tube was apparently already to long on the large.
This.
Posted : 13/06/2014 5:40 pm
The requisite dimensional change can be accomodated by a different stem can't it? Like you originally set out to buy.
I'm confused.
Posted : 13/06/2014 5:41 pm
 hora
Junkyard Ive just re-replaced the 70mm stem on my medium Santa Cruz with the 55mm one I prefer/first fitted.
This is a road bike we are talking about not a mountain bike..
I hate long TTs on mountain bikes. Personal preference..
With a shorter stem my arms wont be locked straight whilst in the hoods will they? It'll force me into a more upright position?
Posted : 13/06/2014 5:43 pm
A need for a shorter stem doesn't normally suggest a need for a bigger bike ..
Posted : 13/06/2014 5:46 pm
you want a shorter reach so you're buying a longer bike?
I wish my wife was as accomodating.
Posted : 13/06/2014 5:48 pm
 hora
Try a 90 stem first? Its only £24 I suppose.
Tbh the frame size decision is much a fault of mine as a busy Saturday afternoon showroom assistants.
So I cant 'blame the shop.
The rest of the bike is fantastic.
Ok down to the shop for the stem post Innerleithen ride tomorrow. Cheers guys 🙂
Mooman that is exactly where I was going with this! 🙂
Posted : 13/06/2014 5:50 pm
Is the stem mounted with a -ve rise? If so, flip it over. Might also be relevant for the shorter stem.
Posted : 13/06/2014 6:03 pm
 DT78
*confused* to be honest if you are clueless I'd stump up the extra for a proper bike fit before you spend anymore on frames and parts. Learnt loads at mine and can fit myself now...and prob a good go at others
Posted : 13/06/2014 6:11 pm
Is this your first darkside bike?. It does take a while to get used to the change in position. I always find people new to do drop bars tend to lock their arms out straight instead of dropping their elbows and leaning forward a bit (I did the same at beginning).
As mentioned a shorter stem and a bit of rise will help, an inline post will give you another 15-20mm if you have a setback. Other than that just some time in the saddle will help get used to it.
I think I am as baffled by this as every one else is.
Here is an idea for you, when you go back the the planet-x shop why dont you get them to [s]advise[/s] sell you a stem that will get your hands as close to the position you are comfortable on on the XL frame with your current frame.
I would be astonished if this is a shorter stem.
This.
But it's a "racer" don't give up on a racy riding position just yet, persevere with it for a while, if you want sit up and beg, a hybrid thingy is what you need.
Posted : 13/06/2014 6:12 pm
 hora
Flipped with higher rise it hurts more (which conflicted/confused me following today as Im not the knowledgable type on road). Its not height its REACH isnt it?
 DT78
Read this for starters
http://www.bikefit.com/s-13-road-bikes.aspx
Posted : 13/06/2014 6:29 pm
And yet you want to buy an XL because it's taller [i]and[/i] longer?! Do you read your own posts?
Shorter stem and get some core strength.
Posted : 13/06/2014 6:59 pm
+1
and do some daily stretching as well
Posted : 13/06/2014 7:04 pm
Will the shop allow you to try some different stem lengths ?
Posted : 13/06/2014 7:13 pm
 IanW
This is a rather confusing thread - you went to buy a shorter stem because you feel too stretched , didn't buy the stem but came to the conclusion the frame was too small and you need one that would achieve the same as buying a longer stem for the frame you already own albeit at 60x the cost.
Mmm?
Posted : 13/06/2014 7:17 pm
Have you people never read a Hora MTB sizing thread?
He is 6ft 1.7 " and rides mediums
If you are expecting sense for him to listen to advise then you are in for an interesting few years
[b] It does take a while to get used to the change in position. I always find people new to do drop bars tend to lock their arms out straight instead of dropping their elbows and leaning forward a bit (I did the same at beginning).[/b]
dont straighten your arms bend at the elbows and tuck
Like this
Posted : 13/06/2014 7:25 pm
Can you just change the fork? Longer steerer + a couple of spacers to raise the stem by 20-25mm, then fit the shorter stem.
Posted : 13/06/2014 7:26 pm
Hora. New forks.
What could possibly go wrong?
Posted : 13/06/2014 7:31 pm
Horizontally, or vertically?
Posted : 13/06/2014 7:37 pm
Hora. New forks. What could possibly go wrong?
Ah. Bugger. Good point.
Posted : 13/06/2014 7:42 pm
Going by the provided information, I'd suggest purchasing an additional medium frame. Take both medium and large frames to a framebuilder and ask them to cut both in half. Get them to weld the front half of the medium onto the back half of the large. Then, fit a 140mm stem to the front and use a 420mm seatpost with half a foot of layback. Finally, fit a set of 20 inch wheels.
You should be roughly in the correct position for a smooth and comfortable ride.
Posted : 13/06/2014 7:46 pm
Do you think it's the colour?? I'd be uncomfortable riding a bike that funny blue colour. Maybe try a respray and swap the 23C tyres for 25C as well - they bring the road alive. 😀
Posted : 13/06/2014 7:47 pm
In fairness to those who haven't met hora, he is an unusual shape.
Posted : 13/06/2014 7:51 pm
 hora
As per usual the answer is supplied then the topic descends into a mosh pit of alcohol and flaying arms
Posted : 13/06/2014 8:50 pm
Short flaying arms though.....
Posted : 13/06/2014 9:20 pm
T. rex stylee
Posted : 13/06/2014 9:36 pm
Personally, I don't believe you have the wrong size, just the wrong set up. Bars are in the wrong position. But I think your saddle is too far back so you are putting too much weight on your arms as you lean forward.
Set the saddle position first to make your core and legs take your weight. Then worry about stem and bar position. It's not rocket science, but I've seen some dreadful fits from some shops.
I'm sure your dimensions are well within the normal distribution. Post a sideways shot of you on the bike. pedals level. On the drops and hoods.
Posted : 13/06/2014 9:40 pm
when i first got my road bike i felt my arms were always stretched out and my hands were a little numbed...
I think it's just getting used to it...
if your bar is obscuring your front hub when you are sat on the bike, it's pretty much bob on.
Posted : 13/06/2014 9:41 pm
 IanW
Think we need pictures, multiple angles, lycra no baggies.
Posted : 13/06/2014 9:49 pm
Posted : 13/06/2014 9:53 pm
Angleset headset bearings flipped 180 bit of reach and sharpen up the steering. win win.
Posted : 13/06/2014 10:00 pm
Did you try flipping the stem first that may be enough to alter your position for more comfort.
Posted : 13/06/2014 10:01 pm
 SamB
I have nothing useful to add, but I would like to say a big "thank you" for [b]yet another[/b] hilarious "Hora bike size" thread 😀
+1 for changing the forks BTW, that'll probably fix it
Posted : 13/06/2014 10:37 pm
 JoeG
How does your position on the new bike compare to your old steel one?
Posted : 13/06/2014 11:55 pm
Hora, why don't you post some photos of the bike as it is now. Side on shot. I'm willing to bet its something as simple as bars rotated too far forwards or saddle too far back.
Posted : 14/06/2014 5:46 am
I feel guilty.when hora posted a PIC of his new bike on Facebook I simply posted "wrong size".The power of suggestion...
Posted : 14/06/2014 6:28 am
May seem counter-intuitive, but try moving the saddle back. You can then easily support a lower crouch (think sticking your bum out when doing a squat). This may help.
Posted : 14/06/2014 6:32 am
Did you have a Retul bike fit at P-X then, and not just some guy looking at you on the bike again? I am surprised they said it was the wrong size, rather than changing the contact point locations..
As alluded to above I don't see why you'd need to change the bike. I think there's a lot of b-s thrown around about frames fitting correctly- out of the box two bikes can feel very different even if they're the same size, but you should easily be able to change contact points so they feel identical.
You've 3 contact points (well 5 really)- hands, bum, feet, and only the cranks location are pretty much fixed in space.
Whatever ideal position the fitter has calculated for you can almost always be recreated on any frame, unless it's several sizes out. Whether it's truly the right position for you is a different matter, but it's a bit early for you be talking about changing the bike.
Rotate your hips forward, flatten/ straighten out your back, that'll help. Build your core strength.
Posted : 14/06/2014 6:46 am
You've all fallen for it!
There is absolutely nothing wrong with Horas bike and he knows it. Earlier this week I sold my bike and bought a new one because it was too big. Hora is blatantly trying the same excuse with his mrs!
Was there a sweepstake on how long he kept this one?
Posted : 14/06/2014 6:59 am
Exactly
One of the most sensible things I've read on the internet was on the website of a custom frame builder. It basically said
"Before we spend several thousand welding tubes together we need to know exactly where you contact points will be and that you have been using them long enough to know that they will work. What we can do one you know where the contact points are is to move the things around relative to the contact points to give a sensible stem length etc..."
Posted : 14/06/2014 7:11 am
Core strength'll fix this.
Anyway, can you wheelie it yet?
Posted : 14/06/2014 7:25 am
Just ride the bloody thing troll boy.
Posted : 14/06/2014 7:42 am
If you ride on the hoods most of time , the position of the brakes can make a difference between 'comfortable' and 'awkward' .
Most / all new bikes come with wrapped bars , when sometimes a rise of 1cm can make a difference to how it rides.
Posted : 14/06/2014 7:43 am
can someone explain what's going on? - because it does sound like Hora wants a bigger bike as it'll be smaller.
Hora; at 6'2" ish, with a 33" inseam, i'd suggest you're exactly normally proportioned.
(says a man who's 6'2" ish, with a 36" inseam)
Posted : 14/06/2014 7:57 am
First, I'd say there is no way of determining what's right and wrong via this (admittedly excellent) medium.
Paradoxically though, 'locked out' arms can be as much a case of sub-optimal posture and a bike actually being too short as much as too long.
I would say see a reputable fitter before spending any more money on kit, if you're in Yorks/Lancs I'd be happy to help: www.fit2ride.cc
If not, I would definitely experiment with different combinations of components on the existing frame before buying another.
Most people can ride two, or even three, sizes of the same frame using different saddle setback and stems.
Posted : 14/06/2014 7:58 am
Apologies for the shameless self promotion in that last post, by the way.
Posted : 14/06/2014 8:01 am
I don't think even he can explain what's going on, as usual.
We are talking about the man who is 'convinced' at comfortably over 6ft tall, riding a medium Santa Cruz, which is hardly regarded as roomy in the TT/Reach department is a good idea.
FWIW - looking at the geometry of your road bike, and being a whole half an inch taller than you, I would have bought the XL. But hey, breaking the habit of a lifetime and buying a bike the right size for you must be hard 😉
Posted : 14/06/2014 8:08 am
My money's on the bike being pretty much right as is, but position all wrong.
After modern wide-barred, sit-up mountain bikes, the road bike positioning can feel strange - it took me a while to adjust - even after 18months I don't settle into it automatically.
Posted : 14/06/2014 8:15 am
 Del
classic. 🙂
Posted : 14/06/2014 8:51 am
For me the oddest thing was, I have a shortish torso to leg length -
I bought a 50cm Bianchi when all the sites say I should be on a 52/53.
Now having ridden it for about 4 years, and stopped riding mountain bikes a year ago when my last one was stolen, I am beginning to find the 50 is too short in the top tube, and that my posture/body shape is slowly evolving to the racer from the mountain bike - In essence, I do now bend further than I did.
So I say, give it time to adapt.
Posted : 14/06/2014 2:09 pm
I'd give yourself more time to adapt, tho I know stw's 2 favourite pastimes are over thinking EVERYTHING and buying new stuff to solve any "problem".
Posted : 14/06/2014 2:49 pm
Skim skim skim.... arms locked out. Road bars have a load of positions, inner tops, outer tops, hoods, in the bend on the drops which one has your arms locked? No good waffling on about which stem you need 90/100/100 etc as you haven't said one position could be miles away from another in bike fit.
Dont get core strength to fit the bike, get a bike to fit your core strength, generally known as the real world.
Posted : 14/06/2014 3:22 pm
Why not put the shifter on your stem so you can reach it? That worked ok on your MTB didn't it? 😯
Posted : 14/06/2014 3:47 pm
I've got it
Aero Bars !
Get the long ones with the forearm pads and micro shifters on the tips.
Must be an extra 30cm reach up front available , just get a pointy helmet , some rubber over shoes and a skin suit and no one need ever know you bought the wrong bike
Just ride everywhere like you are on a 10mile TT , down the shops, to the pub , out across the hills. Just get on the areo bars , get the hammer down and grimace abit. Then in a few months buy youself a disc wheel off PX for the full effect.
tadaaa
Posted : 14/06/2014 3:56 pm
I've never understood this. We all must have seen countless folk piddling about with the bar position to get the hoods in the right place.
Posted : 14/06/2014 4:04 pm
Also arms locked can be because of being overstretched, but also from being too low, the 'fashion' for slamming the stem combined with core strengths that aren't that of Sagans means your arms can be locked just to stop your body falling forward. Using up energy just sitting there.
Posted : 14/06/2014 4:10 pm
Yes, Oldgit. Plus the reason they said go to the bigger frame probably wasn't with 'getting a longer top tube under him' but more a case of 'getting the frame with the longer head tube under him to lift him up'
Posted : 15/06/2014 12:00 pm
Just looked at the geo. The effective tt is only 20 mm and the headtube length is a massive 25mm longer. That height up front (even with 20mm eff tt) should help.
It also shows your height at the upper limit of the large size. Having the longer torso you'd hope that the xl would be better. Are you getting a free swap?
Posted : 15/06/2014 12:03 pm
But it cheap and easy to raise the bars on the existing bike before going to the trouble of swapping frames
Although I think the real issue is that if you are use to a short top tube mountain bike with a short stem the drops on any road bike are going to feel along way away....
Posted : 15/06/2014 2:45 pm
 hora
Never heard an inch called massive before.
Free swap? Trying a 90mm stem first that Ive bought from planetX. 'Free' means a 100mile round trip and a day off work.
Posted : 15/06/2014 3:08 pm
 hora
Ok with the 90stem I can clearly see the front hub and the bike feels abit 'short'. Should be Highish and long not short and high.
Posted : 15/06/2014 4:33 pm
Effective top tube length on the large is 570mm. I'm 6'1" and have 32" inseem, so the same length torso as you do. I've ridden a good few bikes over the years and so reckon I've pretty much got my position sorted. With a 570mm tt and 25mm set-back on my seat i would use a 110mm stem. So depending on your seat position, and assuming you don't have abnormally short arms then somewhere between 110 and 130mm should work.
Posted : 15/06/2014 5:18 pm
so as other have said on page 1, put the original stem back on in the flipped position and do more riding, you need to build your core muscles so you are using your hands to steer not prop you up
Posted : 15/06/2014 5:39 pm
The bike will handle better with a proper length stem, and have better weight distribution over the front wheel.
if you are using a 90mm stem at over 6ft you either have very poor flexibility, are sitting on the bike like a MTB'er/Nodder or are riding the wrong size frame.
Posted : 15/06/2014 7:04 pm
Page 1 / 3
