Can a GS XTR Shadow Derailleur be used with a triple chain ring setup? I know they say it can't but will it work.
Will the only problem be that you can't get all the gears?
Blades
Posted : 22/01/2009 5:03 pm
It'll be fine, as long as you've got a boggo set up (no huge chainrings...) then you'll probably get all the gears no probs
Posted : 22/01/2009 5:07 pm
yep it works absolutely fine
Posted : 22/01/2009 7:14 pm
It'll depend on some things actually, you may find you rip the mech in half when you go big/big, or it'll be slack in small/small. If you can live with the risk that'll happen then it will be fine!
Posted : 22/01/2009 7:49 pm
Thanks people.
Posted : 23/01/2009 3:20 pm
