Numpty night light ...
[Closed] Numpty night light battery question.
My night light battery is knackered, so I want to sort an alternative.
The light runs on 12v.
I have several 11.1 v 800mah batteries normally used to power airsoft guns.
I'm happy that the voltage is ok, tried it and the light is pretty much as bright as before. 800mah seems a bit low to get a decent runtime though so if I wire them both in parallel (pos to pos & neg to neg) will that effectively double the mah but leave the voltage the same?
Posted : 19/08/2013 7:26 am
 Del
yep.
11.1V? how many cells?
Posted : 19/08/2013 7:59 am
Wrong thread..
Posted : 19/08/2013 8:13 am
It's a 3 cell LiPo, each cell is 3.7v.
Posted : 19/08/2013 10:04 am
 Del
hmm. i'd be a bit leary if it were me. those packs are a bit pricey and i don't know a great deal about them. you can get a high mah nimh pack and simple charger for not much. i'd go that route tbh, or just cheapy chinese.
edit: i'm sure they're protected but i'd be concerned about balance between the two packs.
Posted : 19/08/2013 10:53 am
That certainly isn't an issue if you're connecting them in parallel - they'll self balance.
Posted : 19/08/2013 11:08 am
 Del
oh! of course! ๐Ÿ˜ณ
^ that
Posted : 19/08/2013 11:11 am
