numpty disc mount ?...
[Closed] numpty disc mount ? older Trek frame
[#350366]
putting a carbon front fork on Mrs Antigee's commuter a womens specific trek 6700 which is probably 10years old or so and came with vee's - putting a disc on front with forks easy (and essential as no bosses)
rear stay has hose guides and then near dropout 2 unthreaded holes only about 42mm apart (plus a threaded rack/mudguard lug) - assuming fitting a pretty standard sx or slx disc brake say 160mm rotors is this the adaptor to make to what i think is called IS mount?
http://www.chainreactioncycles.com/Models.aspx?ModelID=29507
Posted : 28/02/2009 9:13 pm
Sounds like you need a trek disc brake adaptor. You should be able to order one through any Trek dealer, part #210648.
Posted : 28/02/2009 9:23 pm
Just popped to shed - piccy of adapter on my old Trek hardtail commuter. Mine was a Trek part, so I guess as Simon said above.
Posted : 28/02/2009 9:29 pm
Is the disc brake mount on the chainstay or seat stay, and are the holes facing the ground or at 90 degress to the ground?
Posted : 28/02/2009 9:30 pm
OK so its a Trek specific part - hole position looks just like Fuzzyfelts pic - one of these then gives me what i think is standard IS 51mm apart mounting holes?
Posted : 28/02/2009 9:34 pm
Yep
Posted : 28/02/2009 9:36 pm
thanks to all that helps especially the pic - found one here i think by googling trek specific
http://www.cycleworld.co.uk/category/456/Disc_Brake_Adaptors
never heard of them though!
Posted : 28/02/2009 9:39 pm
whoops confusing link
this one http://www.cycleworld.co.uk/product/9986/Trek_Disc_Mount_Adaptor
Posted : 28/02/2009 9:41 pm
A2Z make a sightly different product that might do the trick if you cant get a Trek speciic one:
http://www.a2zcomponents.com/OLD-web/Adapter/adap01.htm
Posted : 28/02/2009 9:44 pm
thanks Duckers thats useful and has plenty of options
Posted : 28/02/2009 9:46 pm
