nukeproof slx crank...
[Closed] nukeproof slx cranks + xt front mech
[#3942845]
Hi peeps
got my nukeproof built now but have a issue with front mech hitting the frame when fully compressed, has anyone else come arcoss this problem?
thanks
Posted : 04/05/2012 1:46 pm
[url= http://singletrackworld.com/forum/topic/slx-cranks-2 ]see help here[/url]
failing that you've got the wrong mech
why would the slx cranks cause that issue?
Posted : 04/05/2012 1:51 pm
bugger to wrong mech!!
Posted : 04/05/2012 1:52 pm
dont know just thought i say what am running
Posted : 04/05/2012 1:53 pm
MTFU and singlering it
Posted : 04/05/2012 1:54 pm
34.9 clamp Top pull conventional double front mech is the type you need to run
Posted : 04/05/2012 2:02 pm
Top Swing f mech no good on Mega you need conventional top/dual pull double mech.
eg. [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=27692 ]http://www.chainreactioncycles.com/Models.aspx?ModelID=27692[/url]
Posted : 04/05/2012 2:05 pm
ve got a 34.9 XT high clamp dull pull mech
take some pics?
Posted : 04/05/2012 2:09 pm
ve got one of thoses
http://www.chainreactioncycles.com/Models.aspx?ModelID=20685
anygood ?
Posted : 04/05/2012 2:11 pm
thats a 3 speed mech...
Posted : 04/05/2012 2:18 pm
so no good?
Posted : 04/05/2012 2:19 pm
No idea I've MTFU'ed up a long time ago and run single ring up front
I suggest you remove the bash, the outer and middle ring. cut the spider off and only run the granny ring.
that way you have a good weight saving and is maintenance free
Posted : 04/05/2012 2:20 pm
The 3 sp front mech will have a longer cage than the double specific f mech - so lower end of cage will bottom out with a 3sp?
Posted : 04/05/2012 3:19 pm
(Excuse the mini-hijack)
To those that are running single ring here, what chainring are you running, and how do you find it for climbing?
The reason I ask, is that I used to run a 6Point, set up 36/22 and have shifted the same rings onto the Mega. I don't think I could only run the 36, as I don't use it for uplifts/DH (and seem to end up pushing/carrying enough).
So, how do folk find a 32 or 34t?
Posted : 04/05/2012 3:30 pm
