Nukeproof Pulse com...
[Closed] Nukeproof Pulse comp - what springs
I'm in the process of buying a Nukeproof Pulse Comp. I know that it comes with stock springs so I know it will be soft for my weight. The forks I can figure out what I need to buy - the xfirm spring.
For the shock though I'm struggling. The stroke is 76mm - 3 inch. In my riding kit I'm weighing in around 110kg. Looking at TFTunded calculator it seems to indicate that I need a spring around 450lb. Is that right? The springs go to around 600lb and I thought I would have been towards the upper end of scale for weights so was expecting to need a heavier spring. What do folks reckon.
Posted : 27/06/2014 8:42 pm
Without being captain obvious, the best way to work it out is beg, borrow or steal various weight springs til you find one you're happy with.
Posted : 27/06/2014 8:45 pm
I've not got much chance of that unfortunately. None of my riding mates have downhill bikes yet.
I've checked both TFTunded and Mojos spring calculators and come up with different numbers - by quite a way. One reckons less than 450lb whilst the other recommends closer to 550lb. Maybe I should go in the middle and get 500lb.
Posted : 28/06/2014 7:39 am
You can usually pick up various springs cheaply on eBay, pinkbike.com etc, occasionally on here. Usually easy to sell on if they're not right, but a few quid lost getting the right spring is worth it in the long run.
Posted : 28/06/2014 9:15 am
