Nukeproof mega serv...
[Closed] Nukeproof mega service
Anyone know how to get the pivot pins out of a nukeproof mega?? Trying to change bearings and the pins seem pretty well jammed in there!
Posted : 29/05/2015 11:38 am
The upper erosion link just unscrewed with the bolt. The lower however doesnt sem to want to.
Posted : 29/05/2015 12:32 pm
You need to give them a few strong sharp taps with a hammer and something to push them through. I unscrewed the bolt a little and started tapping that, then once moving used a small socket extension bar.
Posted : 29/05/2015 2:23 pm
Cheers, i did try tapping it but guess ill just have to hit it harder!
Posted : 29/05/2015 3:32 pm
Unsuccessful. Just knocked paint off from various places. Weirdly nowhere near where i was actually hitting it
Posted : 29/05/2015 4:05 pm
Undo the bolts and then you should see a shaft/pin with a threaded hole, take a small drift and tap gently and it should move out ok. Same for the linkages and the main pivots.
I also recommend the superstar bearing removal tools I changed all my bearing in about 2 hours without breaking a sweat using them.
Posted : 29/05/2015 4:17 pm
Just seems like its jammed in there. Cant get it to budge at all. Maybe i can get a vice around it and push it out with something?
Posted : 30/05/2015 9:59 am
