Nukeproof Cub Scout...
Nukeproof Cub Scout 24 Axle 2 Crown
Hello all,
Picked up a cheap Cub Scout 24 frame from Wiggles ebay outlet, if anyone has the 24” version, could you please check the Axle to Crown measurement??
Looking at either:
some older 26” forks, maybe reduced down to 80mm travel
Some rigid carbon 26 forks
Cheers!
Posted : 15/02/2024 12:46 pm
Believe it's 494mm. See here: https://www.bike24.com/p2755045.html
If that doesn't make sense I can measure one later on
Posted : 15/02/2024 1:03 pm
The ones I have on my lads are Junit Machete 24" @100 which I believe is what also comes as stock. The A2C is 454mm AFAIK.
Posted : 15/02/2024 1:08 pm
Had the same problem finding forks for a 24" frame. Returned it and bought a full bike. I believe the 26" frames use a 27.5 fork. (Not very helpful, sorry)
Posted : 15/02/2024 2:05 pm
benpinnick
The ones I have on my lads are Junit Machete 24″ @100 which I believe is what also comes as stock. The A2C is 454mm AFAIK.
Good point, didn't actually notice the travel in the link.
Posted : 15/02/2024 2:08 pm
