What are your thoughts on summer/dry weather chain lube ?
silicon based ?
I use pedros road in the summer and atb in the winter. I wash my chain a lot and this stuff cleans up easily. At the end of the day, lube is only there to fill the gaps that otherwise fill up with mud or dust.
Rock 'n' roll extreme is pretty good.
Finish Line pro road
I am getting good results with this [img]
[/img]
Its one heck of a faf to apply but altho I have only been using it for a month or two it outlasts everything else I have tried and does not attract dirt. 1kg for £15 puts all bicycle stuff in the shade. Designed for motocrossers with non O ring chains
I have been using White Lightning dry lube for a few years, which is brilliant for the summer. It keeps everything smooth, dry and remarkably clean. You have to apply it quite frequently though and it is absolutely useless when the season turns muddy.
I'm currently using Prolink, which has been recommended by many. I've only had it a month or two but i'm impressed so far. Seems to be a bit more durable than the White Lightning but has performed similarly (although if you put too much on it can get a bit messy).
Roc N Roll here.....
finish-line dry...all the lube I need
I use a base of Pedro's Syn Lube ATB all year round, then add a layer of Pedro's Ice Wax on top in summer if it's particularly dusty. works a treat.
