Evening all
As above, I only appear to be getting around 100mm travel from my 120mm forks.
If I pump them up to around 150psi they go to around 110 but when I deflate to ~125, which is about right for my weight he travel drops back to 100.
Any ideas what could be causing this? The bike is a 2013 T129.
Thanks all
Have you tried letting all the air out and seeing if they fully compress ? Sometimes the positive and negative air chambers get out of sync.
Thats what I did earlier but have just tried again.
All the air out and then go all the way down but only give about 90mm when reinflated.
Serviced recently?
tomuch oil in the lower legs or compression side maybe
You can let the neg air out of the valve in lower leg under the bolt. Be sure to let all air out of pos first. This may cure it initially. If it doesn't strip em down as some grease may be blocking the transfer port.
The bike was brought new last june and the fork hasn't been serviced yet.
It may just need that doing but wanted to rule anything else out first.
In the bottom of the leg there is a black 5mm allen bolt but I can't seem to undo that. Is this the negative air? valve?
Ok so I figured out it is but I still can't undo the bolt so its largely moot 🙁
