hey guys hopefully someone can help
i am looking for the size what the rear shock should be eye to eye and stroke length as i have just bought a replacement shock working off the old shock size (200mm - 57mm) but when looking at the actual frame i seem to be loosing alot of height there and it seems like the shock should be longer.....
anyone help?
anyone?
shock:7.875x2.25 or 200mm x 57mm for a Norco six three
Are you putting it in the right setting? On my Six Three (now sold, so going from memory) you could install the shock so it would give either 5.5" or 6.3" of travel - the shorter setting made the bike noticeably slacker/lower.
yeah i put in in those settings my shock is that size liftman but once i put the top mount in to get the bottom in the i have to drop the frame down to meet the swing arm which raises about an inch hence the lower frame height just thought that it might have meant to be a larger shock with a larger stroke
