No rebound adjust a...
[Closed] No rebound adjust after lower leg lube.
On my pikes, I just popped of the lowers, relubed and reassembled. But the red rebound knob is very resistant when i try to adjust it. The forks feel fine for now but I'm not sure what could be causing this, any ideas?
Posted : 01/03/2015 10:05 am
Just an idea, but have you tried removing the rebound adjuster and placing a decent 3mm Allan key in there and trying to turn it with that? If it has the same resistance using that then it'll be something internal within the Charger damper that's an issue; Or if it moves freely, I'd check the adjuster you have and see if it is either bent, or if you may have over Torqued it when fitting it?
Just an idea, hope it helps
Posted : 01/03/2015 10:24 am
Wooly, exactly what I have just done. Yep a 2.5mm Allen key spins freely so it must be the adjuster knob. (Hopefully).
Posted : 01/03/2015 10:28 am
Arrrrr, 2.5mm....50/50 chance ๐Ÿ˜€
Either way, as you'll know they're available as a spare part...before getting one I'd try find a mate with Pikes and try theirs first ๐Ÿ™‚
Posted : 01/03/2015 10:36 am
Will do, thanks for the help.
Posted : 01/03/2015 10:40 am
