new T47 'stand...
[Closed] new T47 'standard'
the standard to replace all other standards? well, apart from standard threaded of course...;-)
[url= http://www.bikerumor.com/2015/11/05/industry-launches-new-larger-threaded-t47-bottom-bracket-standard-say-goodbye-to-pressfit/ ]T47 threaded bigshell[/url]
Posted : 06/11/2015 11:07 am
[url= https://xkcd.com/927/ ]https://xkcd.com/927/[/url]
Posted : 06/11/2015 11:40 am
I think that's great. Does a way with a standard nobody likes, works with existing cranks, and it's an open standard for whoever wants it. Win win.
Posted : 06/11/2015 11:48 am
I love the idea but wasn't a big driver in moving to press fit BB's the cost saving to frame manufacturers? This will not deal with that.
Posted : 06/11/2015 11:55 am
[i]"SAY GOODBYE TO PRESSFIT!"[/i]
Praise the Lord.
[i]This will not deal with that. [/i]
Well it will in the sense that manufacturers can put press fit in there as OEM and then you can get the shell threaded and one of these fitted at a later date (warranty willing, obvs).
Posted : 06/11/2015 11:58 am
โ€œYou could literally take a metal PF30 frame and tap it, creating a frame for a threaded bottom bracket. Pretty cool, right?โ€
That sounds like a great idea.
Posted : 06/11/2015 11:59 am
Only if it's a metal shell, a carbon shell can't be threaded can it?
Posted : 06/11/2015 12:00 pm
that's true.
Posted : 06/11/2015 12:02 pm
 hugo
Once manufacturers see that the cost saving of producing press fit frames is outweighed by the reduction in revenue, then there will be change.
I'd avoid a press fit frame if I were buying new tomorrow.
At the moment I'm not sure this is true for the majority (of people not on here...!)
Posted : 06/11/2015 12:06 pm
I'm no engineer, but might you need a thicker BB tube if you intend to cut a thread into it vs one that has something pressed into it?
Posted : 06/11/2015 12:11 pm
Why?? I see no issue with press fit.. have to be the easiest bottom brackets to fit / remove
Posted : 06/11/2015 12:15 pm
Yes, the whole 'thread your metal PF30 frame' thing is just something they added in support of their cause. The truth is unless you get yourself a custom frame (preferably made by the said inventors) with a proper metal shell you won't be able to install those cups.
Or the 'standard' takes off and everyone starts using them.
Posted : 06/11/2015 12:17 pm
I've bought two PF frames in the last two years. I'd prefer threaded as I reckon it's a fundamentally better system but I've had no problems with either (hence why I was happy to buy the second).
(NB - I wrap them in enough PTFE tape before fitting to ensure a tight fit)
Soz, hugo ๐Ÿ˜‰
Posted : 06/11/2015 12:18 pm
xcstu - Member
"I'd avoid a press fit frame if I were buying new tomorrow".
1) they tend to creak, a lot, often from new.
2) you can't fit a square taper crankset in a BB90 - which is a pain in the bum if you want cranks shorter than 165.
3) most people would be more comfortable/efficient with cranks shorter than 165.
Posted : 06/11/2015 12:26 pm
*cough* *ahem*
Some brands never thought any saving or new-stuff sales benefits were worth the hard-to-avoid hassle for the owner or the brand further down the line, or thought the pitch for 30mm axles and BB/PF30 was credible anyway. Not just the bikes I spec but a few others, a minority though. Not being able to fit 30mm cranks has been seen as a negative by some but the 'advantages' of 30mm + PF/BB30 aren't worth the fact it's often a flawed standard in use. TBH I don't think the assembly savings (whatever they are - minimal I suspect) were the main driver, more about BB shell size, issues with threaded cups in carbon bikes, wanting a lighter frame spec, having new stuff to talk about, etc.
This new format looks good, will check the dimensions and combatibility before getting excited by it, initially it seems a good idea. There's not much need for anything bigger than BSA shells on anything but carbon frames though, maybe some heavily OS Ti or Al but not many, threaded inserts / BB cup tool torque on carbon frames is another potentially problematic matter in itself.
My next bike, a steel custom (theoretical) will be threaded BSA unless this allows both larger bearings (a 24mm axle + external cup in a 47mm ID shell combo) as well as the same bearing spacing as BSA HT2 cups - can't see how if you want to use 2 or 3x MTB chainsets. A bigger bearing is potentially no gain if it's closer to the bike centre line, that's the big flaw of BB/PF30 imo. (68mm shell but internal bearings)
Posted : 06/11/2015 12:47 pm
Press fit is bullshit.
I was going through a PF30 about every 2-4 months on my old Stumpy evo, depending how much cash i wanted to spend on the (SRAM up to Wheels Mfg).
Cheapest PF30 is about 30 and they're utter shit quality. Ideally you need a puller/remover to get them out unless your happy to smash them out with a pipe. Then you need to install them with a press tool to get them square.
I'll take a 10 quid Ht2 that i can change in minutes with one "tool" and a hex key every time.
I will categorically never buy another bike with a PF BB.
Posted : 06/11/2015 1:20 pm
