Makes even more sense when you realise how many of them must have been hiding in plain sight out on the trails - lots of reviewers stating they've been on theirs for months.
It seems crazy that Shimano still don't have a single wireless groupset and Sram just keep pumping out more affordable options. I'm more of a Shimano guy, but must admit that AXS is very nice to use (but not convinced I want £300 worth of mech bashing into rocks)
Yeah, as said before….. right now, prices as they are, I would NOT buy a bike with electronic anything.
I already own an S-Works Stumpy, so I’m the right target audience. I’d rather spend the large amount of money on frame and suspension!! Proprietary shock and AXS, not for me.
Thought experiment - how hard would it be to make a retrofit electronic actuator?
What’s affordable? My last rear mech was £35.
Right now I wouldn't buy any bike with electric only shifting. Want the option to fit stuff from other companies. I might change my mind when Shimano brings theirs out, or I might not. I ride with people who have had a lot of problems with the Sram electric stuff. Don't particularly want to have to charge batteries to shift gears either. I like gadgets as much as the next guy but I've ridden bikes with AXS/Transmission and it wasn't doing anything special, except costing a lot.
Of course I'm not actually interested in the new Stumpjumper because I have the current Evo. The new one doesn't appear to be any better except maybe the shock which I've already upgraded.
'' SBC want to sell punters (the wealthy ones at least) a ‘Package’ that “just works” ''
You make that sound like a bad thing. 🙂
Shimano is falling behind. They have some very nice feeling kit but Srams AXS is brilliant.
Setting up new AXS is simple with their free phone app too.
You know life is simpler when you need to download an app. 😀
^ tbh either way, that's me out : ) All this stuff just makes me more appreciative of all that the Cotic and Starling FS bikes are. I'd have one of those and cable XT/Deore mix, JD.
Call me a retrogrough but carbon fibre and electronics just leave me cold. I like bike when they're low tech yet work brilliantly.
My thoughts exactly Jameso, except Orange single-pivot frames rather than Starling now I've sold my Murmur
Orange count, 100% - I just have steel tubes on my mind at the moment
Agreed about carbon fibre...no need for it, but people want it and if you want to sell bikes, you need to offer it. Just wished they do a recycle scheme for them instead of landfill.
“ Call me a retrogrough but carbon fibre and electronics just leave me cold. I like bike when they’re low tech yet work brilliantly.”
My singlespeed hardtail ticks all these boxes (as long as you don’t look too closely at all those shims and ports in the fork damper).
My base model alloy Levo feels kind of simple despite the complicated motor shenanigans - no carbon parts, 10 speed (LinkGlide). The motor makes such a huge difference in my time/energy squeezed life. I’m hoping it’ll keep running happily, it turns six this autumn. I’m concerned that the next Levo might be electronic shifting only which would be so annoying - I like this cheap tough cassette.
Once you have ridden extensively with AXS then cable shifting really does feel archaic albeit not superseded.
It's not essential tech though and cable shifting still remains just as precise and easily maintainable.
It's purely a cost | affordability focus & trade-off.
To the person that said you don’t need the app, when I paired my shifter and mech the buttons defaulted to zero. I.e. when I clicked either button nothing happened and I had to go in the app to set that up. Is my experience not typical?
That doesn't sound typical to me...I paired and it worked. Done it 3 times now.
I think there’s two separate things at play here.
an aesthetic preference for a particular look is hard to quantify. People like the look of different things. Some like skinny tubes, some like swoops and curves.
‘low tech’ on the other hand often means “pick a point in time that you think is perfection and decide everything beyond that it stupid”.
Personally can't wait to see the back of gear cables, always found them annoying to set up and maintain precise shifting on. A lot of that has been down to less than perfect cable routing on bikes and the smaller distance between gears on 11 and 12 speed setups. Wireless does away with all of that and charging a battery is hardly a new thing in 2024.
I think it's much more like K.I.S.S.
Why complicate and add huge expense when the transmission is the least important aspect of an MTB in terms of performance.
There's something very satisfying about only spending where it adds a tangible benefit.
That though is also subjective...it can easily be argued that something like wireless shifting requires less on-going adjustments as there are no cables getting dirty or stretching; the shift is consistent no matter the conditions - for some people those are tangible costs.
I've yet to find anyone who thinks it is a bargain price as it very clearly isn't, but there is slightly less faff and set-up involved - bolt on, adjust b-tension screw, pair and maybe a couple of tweaks of the microshift. Cable is pretty similar but a bit more faff with cable tension and a crisp shift...
Longevity is up there (but this also costs), so that would be another tangible benefit - replace a drivetrain every 3 years instead of yearly (or sooner).
I guess my dribble above shows it can be justified/explained away and appeals to come people whilst others see it as a faff. Charging a battery every 5 or 6 weeks that takes a minute to get the charging started and done in about 1 hour really isn't a big deal. I've said it previously but those who find stuff a faff tend to be the ones that rush out the door and lather lube on a chain as they are off for a ride...a bit of preparation beforehand saves a load of stress and hassle.
Hydraulic brakes...they came on the scene and very few people complained about the set up of them - v-brakes are probably the easiest brakes to set up in terms of speed and ease. Hydraulic brakes require more effort to set them up - but they are now standard as despite this extra work (changing a cable on a v-brakes is about a minute, maybe 2 if you want to do the outer as well), but you really can't bleed a hydraulic brake in that time. People don't tend to moan about brakes and bleeding them - it isn't difficult but can take time...the same applies with gears as well - plenty see the benefits (but the cost is definitely not 1 of them).
“ Longevity is up there ”
This isn’t an issue for the Stumpy but having done a lot of miles on my Levo, I can’t see SRAM cassettes matching LinkGlide ones for the mileage for the price. Hence I’m hoping that the alloy Levo keeps cable routing and/or Shimano make a wireless mech that works with their heavy duty cassettes.
From Guy Kesteven's latest article:
Either way, you’re going to have to get used to frames that only work with radio-controlled ratios as I know there are at least a couple more high-profile bikes coming soon that’ll only have piping for a dropper post and rear brake hose. Or to put it another way, when I asked their distributor if he’d seen how much heat the Stumpy was getting, they replied “Yeah, about that….”
Guy also edited that article to reflect something that many in the industry seem to forget…. Not everyone has access to that kind of money or tech. I’m an exact case of this - I own the carbon standard Stumpjumper 14 comp. It was the top of my budget (although it’s nice to know it can be upgraded in future) - Had it been 2k more upfront with only 1k drive train options as an ownership prospect I’d be out.
Guy basically admitted he hadn’t even thought of it as a problem until he saw all the comments on bike forums as he has constant access to all the latest and greatest tech, as will the Specialized designers. It makes them out of touch. He then added it as a con on his review, so fair play to him.
Hopefully by the time I’m in the market for a new trail bike Spesh will back track. If they build in so much geometry customisation they should include lots of options for building the bike up for all budgets too.
Or even more hopefully Cotic will start to offer a trail bike with either a carbon or steel rear triangle so I can finally buy one of those instead!
My personal choice would be AXS if it came with it however
Looks like it may be the alloy option
I've just gotten back into cycling after about 3 years of not doing so, life getting in the way etc.
My current bike, is an 853 gen 2 slackline, with an XT drivetrain, and due to my work circumstances being what they are now, I've been able to get another bike on cycle2work.
Upper end of the budget for this was/is £4k, and if I'm spending anything like that, there's a pretty decent saving to be had.
Coincidently, the Spec Stump LTD 23 model is £3850 at my Rutland Cycling (local, they take the vouchers) and it's E only shifting too.
And, because it's very different to what I have, and because I rode one, and loved it, I've decided to buy one.
So, I fit the demographic of "would I be spending that much on a bike" and "will e-only shifting stop me", and the answers are yes, and no it won't.
I don't disagree that it has some disadvantages, mostly cost, and the AXS battery thing, but I'm also not selling the other bike.
While I do appreciate I'm in a position of privilege, the fact is it's becoming more and more of a mid life, disposable income, high spend consumer driven market.. I don't think their sales will suffer.
cogwomble
Coincidently, the Spec Stump LTD 23 model is £3850 at my Rutland Cycling (local, they take the vouchers) and it’s E only shifting too.
Pretty sure that bike will have routing for a cable mech - it's only the new '25 carbon version that doesn't. So it will be "e" but not "e only"/
Has having to use an App ever made anything better?
You don't need to use the app though...unless you really want to tinker with it, then it works right out the box - pairing in a couple of seconds, microshift adjustments are done on the controller and setting the b-tension screw is dead simple as well. No app required unless you want to mess with the way it works and reconfigure the buttons or update the firmware.
