New steel frame dis...
[Closed] New steel frame disc brake help?
[#372595]
So i got a new cove frame and have built up just about everything myself, had the bb faced and the headset done by LBS but i was wondering about the rear disc, can i just fit it or does it need facing onto the frame?
Also should i have the LBS look over the build as i want the front hose shortening and have no idea how to do this?
Posted : 08/03/2009 8:13 pm
re. brakes. Try it. If it goes together, adjusts easily and doesn't rub, job's a good 'un. If it doesn't, have the LBS face the rear mounts (may require shimming etc, so give them the rear brake, too).
re. hoses. Shortening them is a 10 minute job (inc. slurping on a cuppa) per side, plus another 10 miuts to bleed each brakes. Honestly, it's so easy you'll wonder what all the fuss was about.
Posted : 08/03/2009 8:27 pm
cheers jimbo well ill try find someone near to sheffield/rotherham who can do it and ill provide the cuppa.
Really wanna learn tho so may hold off the lbs just yet.
Posted : 08/03/2009 8:30 pm
Hose shortening - give the lever a [i]gentle[/i] squeeze with the wheels out. [b]make sure[/b] you dont pop the pistons out by squeezing the lever too much. Undo the fitting at the lever end and remove olive (do all brakes have olives?} Shorten hose and refit. Push pistons back in which will push any air back out of the system. Jobs a good un.
IIRC shitmano need new olives when you do this, hopes can be reused, don't know about others
Posted : 08/03/2009 8:31 pm
to the LBS it goes i reckon it will be worth the money if it means s set up proper.
Posted : 09/03/2009 10:23 pm
