New pump required
[Closed] New pump required
[#5310897]
Basically I'm after a new pump to take to the trails. I want one of the larger micro pumps as um sick of 300 stroke to inflate a tired I'm thinking either Lezyne micro floor drive or topeak mountain morph. Anyone have experience with either or know of a better alternative fir around the same price? 25 quid ish. Cheers chris
Posted : 07/07/2013 11:11 am
I have the Lezyne Alloy drive. Very nicely made bit of kit. High quality and works well.
Posted : 07/07/2013 12:07 pm
Also have the Lezyne Drive, occasionally screws the valve core out when you remove it but otherwise fine. A push on adaptor is available for Presta valves.
Posted : 07/07/2013 12:14 pm
+1 for the Lezyne
Posted : 07/07/2013 12:29 pm
Looking like that then. Was concerned about it removing the inner valve as my mate's screw on dies this and it's bloody annoying!
Posted : 07/07/2013 2:30 pm
Just bought a topeak Mountain Morph after researching on here, best pump I have ever had
Posted : 08/07/2013 2:21 pm
Mtn Morph or one of it's many clones for me
Posted : 08/07/2013 2:24 pm
I have this problem too, it makes the pump basically unusable IMO - which is a shame because up until the point it pisses all the air out of the valve it's a great pump! Don't suppose you have a link to the adapter?
Posted : 08/07/2013 2:45 pm
M:Parts Evolution (also sold variously as Truflo and Outland I think)- like a mountain morph but cheaper and the foot doesn't fall off as much.
The drive is classic lezyne- a slightly wonky idea, beautifully executed.
Posted : 08/07/2013 2:52 pm
I think they are fixed the issue with unscrewing valve inners on the newer Lezynes?
Do the ones people are having problems with have a little press valve on the side of the adaptor hose?
I like my alloy drive, it just works, & can get the pressure high enough without being ridiculously hard.
Posted : 08/07/2013 3:42 pm
The push on adaptor came with my Lezyne floor pump but is available separately. It's call a speed chuck, on eBay for about £6 ish. Bit pricey for a bit of plastic but works fine.
Posted : 08/07/2013 3:57 pm
