New brake hose... c...
[Closed] New brake hose... can't bleed!?
[#9336115]
Just put a new rear brake hose on my Hope E4 brake... now I can't seem to bleed the damn thing.
Usual bleed procedure followed like I've done many a time before but when I pull the lever the fluid level in the reservoir stays the same (bleed nipple on calliper end is open so air and fluid has somewhere to go)
So I removed the hose from the calliper end incase there was some kind of airlock but still the fluid level in the lever reservoir stays the same when I pull the lever....
So I took the hose off at both ends and I can blow air through it so it's not blocked...
I pulled the lever with the hose disconnect and fluid shot out the end so the lever is doing its job...
Reassembled and the problem persists...
Any ideas?
Posted : 18/05/2017 8:56 pm
have you tried reverse bleeding?
Syringe on bleed nipple[ with pipe etc] and pump upwards to the lever
Posted : 18/05/2017 9:04 pm
Bingo! Thanks Junkyard!
Used an old non-stealth reverb syring to put some fluid in from the calliper end. Everything back to normal now!
I wonder why the lever wasn't pushing fluid into the hose before when there was air in there??
Posted : 18/05/2017 9:23 pm
I once tried bleeding the front lever and rear calliper, worked quite well bizarrely.
Posted : 18/05/2017 9:25 pm
