Need a new cassette...
[Closed] Need a new cassette. Advice please.
[#10398429]
I need a new cassette. I'm running Shimano 105 5800 at present. These seem a bit scarce but I've found a 7000 of the right ratio. Is there any difference in real terms between the two? Used for road riding with a full 105 groupset. Chain and front rings are also worn but they are readily available.
Posted : 19/12/2018 7:50 pm
As long as it's got the same number of sprockets, will fit the freehub and doesn't have wildly different ratios, completely interchangable. You wouldn't even have to stick with Shimano.
Posted : 19/12/2018 9:54 pm
Thanks. That's what I thought.
Posted : 19/12/2018 10:02 pm
R7000 is the new Shimano code for 105. It’s just a bit newer than the 5800 but will work fine
Posted : 19/12/2018 10:31 pm
Excellent. I'd guessed that but never trust companies not to change some trivial item that means the whole system needs replacing.
Posted : 19/12/2018 10:38 pm
