trying to problem solve anyone got the same setup anywhere near me Lichfield Staffs.
No power battery seems to be charged (green light) but without the battery attache d the charger still stays green!
Cheers Rich
I'm in Tamworth but my battery is still on it's way from DX. If you can hang on another two weeks or so then you are more than welcome. ๐
If you're coming to the wobble I'll bring one along for you to try.
Stu Tite has one Rich
Rich, I had a similar problem. The battery pack got v wet, water seemed to have got under the heat shrink. Looks like one of the components on the pcb in the battery pack was not properly fixed to the board. Hopefully a mate if resoldering. Yours might be the same problem?
It is a battery problem corrosion on the pcb needs a clean and a resolder ๐ก
Wrap the batteries well people!
