Mr BoingBoing?
is it a marzocchi nipple top?
any you can berate the cleanliness of my manshed...naturally
it is definitely a marzocchi 120/140mm ish travel, two schraeder valves at the crown but no other adjustment
Marzocchi of some description, with aftermarket dust caps on the air valves (the originals do have a bit of a tendency to loosen off)
I would guess perhaps a DJ of some sort, owing to the lack of lockout and relatively short travel. Does it have any adjustment on the damping at the bottom of the legs?
My first thought is 'zocchi Dropoff's but those caps certainly aren't standard issue.
What sort of travel do they have?
Either that or I've always thought that 'Brian' is a good name for a fork.
Marzocchi XC500 from 2008-ish?
All black, 32mm stanchions, 100mm travel.
I would have said Marzocchi drop offs, due to the fact they're long(ish) travel and have a qr drop out. DJs were 100mm travel or less usually. Drop offs were anything from 130-150mm i think.
on second thought maybe a DJ3 i think they had QR dropouts.
All mountains if theyre 150
No adjustments on the fork leg bottoms just shiny silver 10mm ish bolt heads
Donald
Call me rain man.
Fred? Is that you? ๐
