my crank fell off t...
[Closed] my crank fell off today....why?
 ton
riding in to work this morning, my left crank fell off my bike.
it is a shimano ht2 set up. all fitted by me, and it has been running good from day one.
on inspection, the cinch bolts were still tight, the cap that preloads the arm appears to have unthreaded out of the end of the axle. and the little pin on the black spacer has gone.
any ideas why this should have happened?
Posted : 17/11/2017 10:36 am
 JAG
Lack of maintenance 😆
My point being that there’s not an epidemic of these failures therefore there must be something faulty about yours. I have outlined the most likely fault 😳
Posted : 17/11/2017 10:37 am
lack of the preload cap or the little pin won't cause the arm to fall off.
Loose pinch bolts and/or damaged splines is the cause.
How can you tell pinch bolts were still torqued up correctly if the arm's no longer ont he axle?
Posted : 17/11/2017 10:39 am
Throw that stupid plastic one away and get an alloy one from Ebay, they are under a fiver. Basically it fell off because it's old and worn. People say you don't need the torque plastic bit to keep it on but in my experience you do if the cranks a few years old. As I say get an alloy one from ebay, they come in all colours and are usually just a couple of quid. Filter results to UK only as there are loads in china.
 ton
cinch bolts needed allen key to open them. cheched splines, all seem intact and fine.
crank went on fine when I installed it, the pin sat in the hole on the axle fine.
proper odd.
and it was all new in august.
Posted : 17/11/2017 10:41 am
[i]cinch bolts needed allen key to open them[/i]
aren't they threadlocked when new?
Posted : 17/11/2017 10:43 am
 JAG
Given the time-in-service is relatively short I’d also like to add ‘incorrect fitting’ to the list of reasons for the failure 8)
Posted : 17/11/2017 10:45 am
Did you notice any play in the cranks beforehand?
The plastic cap doesn't really do anything except preload the bearing, the little plastic tab which locates into the axle hole isn't under any load so it's a bit bizarre that the non-driveside crank bolts are still tight.
I'm grasping at straws really, but have you had cause to swap out the crank bolts at all?
[edit]
I note that from the OP's update that the entire crank is only a couple of months old and that everything would be in good order.
Like I said, bizarre.
Mine did the same, once it happened the first time, it would happen again, then again.... It was the only crankset i had that did it and i'd owned a dozen HTII cranksets by then. I'm not convinced if i ever got to the bottom of it. It may have simply been the preload nut jobbie as stated though.
Posted : 17/11/2017 10:46 am
maybe you just hadn't done them up tight enough then.
It's a bit disconcerting when it happens int it. Did you lower the saddle and scoot bone shaker style to your destination? That'd be a sight to see.
This - had exactly the same thing on my 105s. I slightly bolloxed them doing a roadside repair with minimal tools and a rock, but it hasn't worked loose since replacing the end cap and refitting.
Posted : 17/11/2017 10:48 am
The baby jesus hates you.......or aliens.
Posted : 17/11/2017 10:49 am
This was my understanding, but it seems to have a role - my pinch bolts were correctly torqued on install but the plastic plug had come out - the cranks seem to work their way down the spline without it.
Posted : 17/11/2017 10:50 am
 ton
yeah right, cos I have never built a bike up before.
I sat sulking until my lad collected me.
refitted it,and had a spin around and it seems fine.
alloy preload thing will be ordederd
For info, if you get some of the Perdos type thick width tyre levers, they actually fit perfectly inside the standard nut thing for tightening it up trailside
Posted : 17/11/2017 10:52 am
weeksy - Member
While not as easy to use, from the depths of my mind I seem to remember that a 20p will also fit into the pre-load nut & can be used as asn emergency tightener.....
Could be a load of rubbish though (I need to remember to try this later).
Posted : 17/11/2017 10:57 am
You can usually find a small rock that'll fit too, I've had this a number of times in the past. I can only put it down to me fitting them wrong somehow, it put me off shimano cranks for ages but my current set are fine. In my experience if it's happened once it's going to keep on happening but maybe a metal preload thing will help.
+1 for Pedros tyre levers and 20p coins.
I have had an XT crank loosen itself, but this was entirely down to my own ineptitude when fitting with PF46 axle spacers - not I hasten to add, that I'm suggesting that the OP has fitted cranks incorrectly!
Might be worth making a warranty claim.
Posted : 17/11/2017 11:12 am
He didn't say that. You have a product which is successfully fitted to literally millions of bikes, 99.9999% of which have no problems. Yours fell off after 3 months of ownership. There's no inherent issue with the product, neither generally nor in this specific case. Ergo the obvious cause is that it was fitted wrong.
I had one come loose, it didn't actually fall off, it rotated slightly on the splines, which is probably more damaging. Just one of those things, it obviously wasn't tight. Be glad it's done no damage, shrug your shoulders and move on.
Posted : 17/11/2017 11:19 am
 ton
alloy preload thing ordered. didn't realise alloy ones were available.
cheers all.
Posted : 17/11/2017 11:24 am
Doesn't mean they were done up correctly, just that they were tight in their threads.
If you're relying on the bearing pre-load cap to keep your crank arms on, there's a bigger problem with the cranks.
Posted : 17/11/2017 11:26 am
One of the reasons that it is plastic is that it makes it harder to overload the bearings. Also why you should only tighten it up using your fingers, not a tool with any leverage. It should be playing absolutely no part in keeping the crank on once the pinch bolts are done up.
Posted : 17/11/2017 11:29 am
Never had any problem just jamming a normal tyre lever in on the rare occasions it's necessary to do up one of those end caps without the tool.
I would err on the side of installation issue, but have seen a friend's cranks exhibit similar behavior. Alloy nut seemed to slow it down but not stop it. Eventually that fell off in the bushes and we ended up using zip ties through the centre of the axle and around each arm to maintain preload to get home.
I have also seen someone happily riding around for some time without the end cap at all because he hadn't got round to ordering one yet.
Posted : 17/11/2017 11:33 am
warning,
its still possible to fit inccorectly even with the blingy alloy nut (that does nothing the plastic one didnt do ;))
Posted : 17/11/2017 11:40 am
I've been riding round for 8 or 9 years without an end cap on one of my bikes.
You can pretty much get the right end load by just pushing the two halves of the crank together....... then getting someone else to nip the first cinch bolt up.
Posted : 17/11/2017 11:48 am
did you grease the splines before fitting?
Posted : 17/11/2017 12:05 pm
Aren't the splines pre-greased? I'm pretty sure that both of my XT cranksets were.
Posted : 17/11/2017 12:08 pm
Also check spacers.
If there is too many on one side there could not be enough support on left hand arm.
One lad I know did this.
Arm dropped off in the middle of nowhere!
He brought no tools!
Lucky i was there!
Max
Posted : 17/11/2017 12:12 pm
IME if it's fallen off once the soft alloy splines in the pedal are now damaged (which is not particularly visible) and will keep coming loose unless you over torque the pinch bolts, and even then it might still come loose.
Posted : 17/11/2017 12:20 pm
Also check spacers.
Only if there are too many full stop, doesn't matter where they are. If you have a 73mm shell and have >1 spacer then that could be a contributory factor.
Posted : 17/11/2017 12:23 pm
new HT2 cranks often need a re-pinch a while after installing. they take a bit of bedding in - maybe too much grease or something.
Posted : 17/11/2017 12:25 pm
Is it an MTB crank on a [url= http://singletrackworld.com/forum/topic/mtb-crankset-to-replace-a-road-cranksetok ]road BB? [/url]
Posted : 17/11/2017 12:33 pm
 ton
there was only 1 spacer, on the drive side. now removed this and refitted the whole lot. it seems ok, we will see.
Is it an MTB crank on a road BB?
yes it is. deore crankset onto a tiagra bb.
Posted : 17/11/2017 12:45 pm
It's hollowtech 2 isn't it?
So you have a right hand tiagra crank and a left hand deore?
Why not just use a pair of tiagras?
Posted : 17/11/2017 12:49 pm
Saint cranks come with an alloy pre load cap.
Posted : 17/11/2017 12:51 pm
 ton
yes.
no I have a deore crankset on a tiagra bb.
Posted : 17/11/2017 12:54 pm
Ah, clear now, you mean the bearings. Which might be a problem, i think they are thicker. by a mm or so. So thicker bearings and a spacer, hmmm. Might just not have had enough engagement.
Posted : 17/11/2017 12:57 pm
 ton
space is removed. bb on my bike is thicker than a bb in my spares box. just measured it.
spacers removed. hopefully now sorted.
Posted : 17/11/2017 1:00 pm
This happened to a friend, once it had loosened it would never stay on again, no visible damage but the damn thing was goosed for some reason.
It only fell off after he lost the plastic cap, whether that was a symptom or a cause I don’t know. I always assumed they play no part in holding the crank on but after seeing it with my own eyes I’m no longer convinced.
Posted : 17/11/2017 1:26 pm
JAG - Member
ton - Member
Posted : 17/11/2017 1:38 pm
This. Due to incorrect fitting on my part. The end cap does not have a role in holding the bugger on, but if the crank/axle join fails, it's the last thing to go before your crank is bouncing along the trail.
Posted : 17/11/2017 1:39 pm
Are we sure MTB cranks work ok on road bbs? Cos there certainly weren't many replies to that original thread. Meaning, to me, that nobody does this!
Maybe it's just spacers, but maybe not enough (or too much?) spline is available for the left arm to attach to. I'd measure to be sure.
Posted : 17/11/2017 1:56 pm
 ton
it has done 6 weeks commuting since fitted. hopefully now the spacers are removed it will be fine. fingers crossed.
Posted : 17/11/2017 2:02 pm
There is also that little hook in the crank arm which is meant to help prevent the arm falling off if things get loose. It shouldn't close fully if the crank isn't seated correctly, as far as I am aware.
Posted : 17/11/2017 2:04 pm
HT2 cranks are only compatible with their own bearings ie road cranks ->road bb’s, mtb cranks -> mtb bb’s. There is 1mm difference between the cup sizes that cannot be correctly adjusted for by the 1.5mm bb spacers.
Ditch the tiagra bearings and fit deore.
Posted : 17/11/2017 2:06 pm
I'm flummoxed why you lot are going on about the bearing preload nut.
It serves no retention purpose. All the work is done by the pinch bolts.
This happened to me once on a new set of ht2 cranks. I installed the bolts without grease and they weren't cranked as hard as I thought. I had to relctantly conclude user error, even though I'd built loads of bikes, I made a mistake.
The spline in the crank arm was damaged and it never fitted properly tight again and persistently worked itself loose so I had to bin it after that.
You're a big lad ton, you've just dragged it off the end of the axle.
Posted : 17/11/2017 2:20 pm
[i]yeah right, cos I have never built a bike up before.[/i]
[i]I have a deore crankset on a tiagra bb. [/i]
Posted : 17/11/2017 2:46 pm
It fell off because it was incorrectly fitted using incompatible parts.
You need a Shimano mtb bottom bracket and no spacers. Using a road bottom bracket will mean that there is 2mm less engagement on the splines than there should be. You may get away with it but why risk it? With the wider road bottom bracket and a spacer there was no way it was going to stay attached long term.
Posted : 17/11/2017 2:53 pm
 ton
no I don't. I need a shimano mtb 68/73mm bb with 1 spacer at each side.
a shimano tiagra 4700 bb is also 68mm.
I have now fitted a deore bb with 1 space each side.
Posted : 17/11/2017 2:58 pm
Did I actually get something right?? 😯
Posted : 17/11/2017 3:01 pm
 ton
no ideas Dez......my head is fubar now.......... 😆
Posted : 17/11/2017 3:02 pm
Doesn't a 68mm bb-shell need one spacer drive-side and two on nds for Shimano mtb stuff?
Posted : 17/11/2017 3:15 pm
One on NDS, two on DS with MTB BB on 68mm shell.
Posted : 17/11/2017 4:32 pm
Shimano road BB cups are 1mm wider than MTB ones.
So although both are 68mm shell fitting with no spacers your actual space between cranks is now 2mm wider than had you used the right BB.
Posted : 17/11/2017 4:43 pm
I'd have thought the plastic hook wouldn't have fitted into the hole in the axle if the cranks wasn't engaged enough (having said that, I've never checked for tolerance).
Posted : 17/11/2017 4:47 pm
 ton
just rode home and survived the bb/crank apocolypse...... 😆
Posted : 17/11/2017 5:02 pm
scotroutes - Member
Having read the instructions, I'd have thought the plastic hook thing was specifically put there for the express purpose of checking the crank was on properly before tightening the pinch bolts. You can't push it in if the crank's not on properly.
Posted : 17/11/2017 5:07 pm
One good thing about PF bearings was it did away with all the spacer malarkey!
68mm shell: 1 NDS, 2 DS
73mm shell: 1 DS
E-type front mech or chainguide? Replace one from DS.
Get the right BB and use the right spacers. Done.
Posted : 17/11/2017 5:31 pm
Yeh, they're a shit design. Replace them with a SRAM chainset as they don't suffer from this problem and far easier to remove/install.
Posted : 17/11/2017 5:43 pm
For sure it's almost like they knew you would have it on and off alot with their shit bearing quality 😉
Posted : 17/11/2017 6:15 pm
😀 was hoping someone'd post that
Posted : 17/11/2017 6:16 pm
Shimano MTB and Road BB cups are the same size. The only difference between them is the length of the threads on the DS which are usually longer for MTN than for road. Road BBs are also usually for 68mm shells, so have smaller connecting shafts. As Njee says above, just use the spacers appropriately for the shell size.
I have MTB Cranks on road BBs and MTB road cranks on MTB BBs.
The Preload screw is just that, finger tight with the tool (or a pair of opposed butter knives), make sure the plasic pin spacer between the bolts on the NDS crank arm can home into the hole on the axle, then tighten the pinch bolts to the correct torque.
Posted : 17/11/2017 6:27 pm
 ton
so my tiagra bb with my mtb craks were ok, just as i thought.
the plastic flag with the pin did drop in the hole on the axle when i built the bike. just has it did on every (lots) bike i have ever built.
taking my tiagra bb out and fitting my deore bb with spacers made no differance.
my crank falling off was just one of those unexplained things.
if it happens again i shall install a thing like a old fashioned head doctor. a length of threaded bar with a washer and nut on each end, to old the whole lot in place. sorted.
Posted : 17/11/2017 8:05 pm
I’ve played this game (but opposite to Ton) - 105cranks with XT bb. It doesn’t work - the 1mm difference between the width of the outer face of the bearings can’t be sorted properly with the 3spacers irrespective of the frame bb shell width.
Posted : 17/11/2017 8:48 pm
I'm confused reading this 😀
Posted : 17/11/2017 9:16 pm
 ton
not as confused as i am typing/explaining it........ 😆
Posted : 17/11/2017 9:18 pm
lol
Posted : 17/11/2017 9:40 pm
 JAG
Hahahahahahahah De-nile is not a river in Africa
Posted : 17/11/2017 10:41 pm
[quote=philjunior ]Having read the instructions, I'd have thought the plastic hook thing was specifically put there for the express purpose of checking the crank was on properly before tightening the pinch bolts. You can't push it in if the crank's not on properly.
Are you suggesting the OP hadn't fitted them properly?
Posted : 17/11/2017 10:45 pm
Well he now has said he did that but right, so it must be the pinch bolts being under tightened that actually led to the crank falling off. It is worth giving them a check over the first couple of rides so could conceivably have been tightened right but loosened off.
Although I've no idea what is going on with road vs MTB BBs.
Posted : 17/11/2017 11:43 pm
I ran XT cranks with a Dura Ace BB and a spacer removed circa 2007 and that BB lasted forever, including a season of XC guiding in Whistler.
Posted : 18/11/2017 5:54 am
