The tool that is sticking up. It's about 8x3x15mmm, with slightly pointed edges.
Posted : 21/10/2020 9:31 am
8mm?
Posted : 21/10/2020 9:33 am
8 or 10mm would By my guess
Posted : 21/10/2020 9:34 am
it's for getting stones out of horses hooves.
Posted : 21/10/2020 9:35 am
Oh yes, it does fit an 8mm socket!
I think thats a space saving, and not very good 8mm hex key
Posted : 21/10/2020 9:38 am
Yeah, I can't imagine it will work very well with a tight 8mm bolt.
Posted : 21/10/2020 9:51 am
The SWAT tools are more for getting you home, so if your crank came loose you're able to tighten it up enough to get back.
Posted : 21/10/2020 9:57 am
glenh
Yeah, I can’t imagine it will work very well with a tight 8mm bolt.
On the other hand it's better for tightening a loose crank bolt out on the road than the 8mm you didn't take because it was too bulky.
It's a just in case tool, better than nothing.
Posted : 21/10/2020 9:59 am
yep, 8mm allen key bit
Posted : 21/10/2020 10:09 am
2x4mms can also be used.....
Posted : 23/10/2020 9:51 am
