Mucoff and contamin...
[Closed] Mucoff and contaminated pads ?
[#2376311]
Anyone found Mucoff kills their pads ?
For years I had no problem - always used it, always used sintered pads. Both expensive OEM ones and the cheaper version off the web.
Just recently though, I found Ive got no more than two rides out of a set of sintered pads on my bike before they failed to stop me. Twice in two weeks this has happened - its expensive as well as frustrating.
Posted : 17/01/2011 12:54 pm
I've never had that problem and can't see why it would, unlike GT85 liberally sprayed around?
Could the loss of braking power be related to a post-Xmas increase in weight rather than pad contamination 😉
Posted : 17/01/2011 1:09 pm
Ha ha, yes Roger, or is it because I now ride faster 🙂
Joking aside, actually Ive tired everything. No liberal spraying of GT40/WD85, no leaking forks / calipers etc. Im sending the pads back for investigation. Im also trying a different make.
Posted : 17/01/2011 1:59 pm
 7hz
I am totally fed up with my brakes. Similar thing - pads work ok for a ride or two, the develop a banshee like howl and don't stop as well.
Tried removing them and boiling pads / sanding pads and discs at the weekend - no improvement.
I have noticed this happens when not using any cleaning products - bike just cleaned with water.
I don't know what happens, but I am starting to suspect salt on the roads may be an issue.
What make are your breaks / pads? Mine are currently Shimano LX / Clarks pads. Dame thing happened with Shimano pads and other brands I've tried.
Posted : 17/01/2011 7:40 pm
7hz - sounds to me like your shimano piston seals are on their way out ....
Posted : 17/01/2011 7:51 pm
 7hz
Thanks for the reply. How would the piston seals be affecting this?
Posted : 17/01/2011 8:09 pm
My front has started doing this.
How does it make the seals go out?
Posted : 17/01/2011 9:35 pm
Try some copper slip on the back of the pads, this helps with screaming brakes something to do with vibration against the pistons, SIB
Posted : 17/01/2011 9:52 pm
