moving from post mo...
[Closed] moving from post mount to IS
Hi, a friend has upgraded his forks, the disc mount on the old ones is post mount and the new ones are IS.
I know he'll need a new adaptor for them, (Avid Juicy 3) & I've found the right one on CRC but it doesn't come with bolts, which I can't find on there, does anyone have any ideas where I can get some?
From memory post mounts use two long bolts, whereas IS requires two pairs of shorter bolts.
Posted : 07/06/2009 9:23 am
They are just stock bolts. M6??????
Posted : 07/06/2009 9:45 am
Cheers TJ,
That could be a solution. However he's just getting into mtbing and I think he'd be happier if there was a definite product he could use rather than me rooting through my spares finding something which 'should' work.
A good back-up solution though 🙂
Posted : 07/06/2009 10:15 am
You need x 2 M6x20mm bolts.
A local bolt supplier can supply these for about £1 but if you must have a "proper product" then look at the bolts available from Shimano, Hope, Formula it's all the same thing.
Alternatively buy whatever size adapter you require from Hope as you get the adapter and bolts in the price. As long as it is the same size you can interchange adapters regardless of brand.
Posted : 07/06/2009 10:23 am
Cool, it didn't occur to me that you could use different brand's. the hope one looks good.
Posted : 07/06/2009 11:16 am
