Most ridiculously o...
[Closed] Most ridiculously overpriced piece of bike bit
Any bike lubricant with the words "juice" or "butter" in it's name to disguise that fact that it shares it's origins with much cheaper stuff.
Take Finish Line Teflon Grease - remove the label...ah, White Lightning Pool and Spa Lubricant. So much for being "Formulated for the unique and demanding non-hydrodynamic requirements of a bicycle bearing".
Posted : 24/01/2012 2:28 pm
 Sam
PrinceJohn - Member
Today I was quoted by the bike shop for a new brake lever assembly, for my avid juicy ultimates after the bolt the mount had cracked...
£180.00
just for this bit....
Same thing happened to mine - I think I have another lonely lever somewhere if you are interested...
Posted : 24/01/2012 6:23 pm
The Garmin cable is outrageous
Posted : 24/01/2012 6:44 pm
The Intense dropouts are astonishing, at that price you could actually buy a small milling machine and make your own for less.
(ok, obviously you'd actually just totally fail to make your own, and get swarf in your eyes to boot, but in theory you could)
coatesy - Member
After all these replies I can't believe nobody has mentioned 9 quid for a small sheet of thin plastic and a little roll of velcro to strap to your fork bridge.Suppose i'd be too embarrassed to bring it up if i'd been mug enough to buy one.
Weeeeellll... This is where it gets less simple isn't it. Because sure, everything you say is correct but at the same time, I can't think of anything else I've bought for under a tenner for a bike that's been so brilliant. VFM is about cost vs benefit as well as cost vs production cost IMO.
Posted : 24/01/2012 7:30 pm
The Garmin cable is a rip, but I believe that their devices are quite flaky when connected to the PC with a normal USB cable. I know mine struggles if it's not being treated as a USB hard drive on a normal cable. No excuse I know, but I believe that's what someone might buy that cable.
Posted : 25/01/2012 12:11 am
the £80 labour on a fork service.
I agree with this it took 1/2 hour to service an old pair of Dukes if they have to get sent away for a service I may as well buy new ones
Posted : 25/01/2012 12:21 am
SRAM powerlink [url= http://www.evanscycles.com/products/sram/powerlink-silver-chain-connector-8-speed-ec008053?query=SRAM%20power%20link ]Evans £15.99[/url]
£3.99 for 3 at CRC
Posted : 25/01/2012 12:34 am
Page 3 / 3
