Brake advice
[Closed] Brake advice
[#3598755]
Looking at changing my current brakes on my 2006 enduro s-works and need some advice.
Currently using Hope Mono 6ti with 200mm rotor on the front & Hope Mono M4 with 180mm rotor on the rear.
Am planning to change my chainset to xt groupset so considered the new xt brakes, how would these weigh up would i need the larger rotors still?
Any advice would be greatly appreciated
Posted : 23/01/2012 3:09 pm
Why do you want to change?
Posted : 23/01/2012 3:11 pm
Agree with TJ, Hopes are ace, why change?
Posted : 23/01/2012 3:14 pm
The rear lever has one bolt hole threaded so wont come off but does move a bit. They are quite old and although well looked after i do like the new tech levers..
And when i change my groupset i could use the xt brakes..
Posted : 23/01/2012 3:16 pm
Get the Hope V2 brakes, utterly brilliant brakes. The masses will say Shimano but thats just boring
Posted : 23/01/2012 3:33 pm
I would simply helicoil the damaged thread.
Posted : 23/01/2012 3:34 pm
I did consider doing a helicoil but if it doesn't take i won't be able to put it back on as the other thread is weak also.
How do the shimano xt brakes hold up against the hopes?
Surely if i was to replace with new hope brakes the tech m4's would be the ideal replacement?
What about avid? the bike is setup as an all mountain machine and i ride hard on the downhill stuff
Posted : 23/01/2012 3:59 pm
