Morzine maps
[Closed] Morzine maps
[#4109359]
Hi, anyone out there got any trail maps or any advice on finding the best stuff out in portes du soleil. We will b riding 140mm travel trail bikes we will be dabbling in a bit of DH but also fancy some good off piest knarl and freeride.
Cheers.
Posted : 27/06/2012 8:39 pm
You can get (or did) a PDS map from the tourist office - its like a OS Map without the symbols, but has the PDS route on it plus the usual DH routes, VTT routes, plus `paths' to explore.
Posted : 27/06/2012 8:51 pm
Cheers, sounds like what am looking for.
Posted : 27/06/2012 9:20 pm
Just fished mine out and it funnily enough is called Les Portes Du Soleil and a 1:35000. Has also piste map stylee zooms of the main areas ie Les Gets, Chatel as well as plenty of detail outside the Stormtrooper areas.
Posted : 27/06/2012 9:33 pm
for starters - Some of the areas produce their own maps which are quite good (Les Gets, Chatel) others not so good (Morgins/Croset) and others don't seem to bother (Morzine/Avoriaz) you can follow the links to their sites to see what detail you can get this year. The 3€ map from the morzine lift pass office was normally a good bet.
Posted : 27/06/2012 11:46 pm
[s]I have a PDF of the offical trail map - cannot recall where online I found it. If you send me an email (in my profile) I'll send you a copy.
[/s]
[url= http://www.lesgets.com/medias/docs/vtt/LesGets_bikepark_plan.pdf ]Morzine/Les Gets Trail Map[/url]
Search the old threads here, there are lots with trail advice on, eg ...
[url= http://singletrackworld.com/forum/topic/anyone-know-where-this-is-trail-in-the-portes-de-soleil ]Thread[/url]
[url= http://singletrackworld.com/forum/topic/route-from-les-gets-to-samoens ]Thread[/url]
Posted : 28/06/2012 8:42 am
