Monarch rt3 deb, Ai...
[Closed] Monarch rt3 deb, Aircan removal
[#10752694]
Ok what am I doing wrong, I have one end clamped in a vice and the air can is just rotating and not coming off.
Don't have a strap wrench, is that the issue?
Posted : 05/08/2019 8:03 pm
If it's the same as my plus, there's an o ring at the bottom of the air can(closest to the eye). Use a pick to get this off, then the air can just pulls off. With a bit of wiggling.
Posted : 05/08/2019 8:10 pm
And dont forget to depressurise the shock first.
Posted : 05/08/2019 8:18 pm
It is a pain, I really struggled with mine. I think the factory gets a bit excited and screws it too tight to take off by hand. I now own a strap wrench.
Even if you have pulled the outer off as above, you still need to unscrew the aircan proper.
Grip it at the bottom with the strap wrench.
Posted : 05/08/2019 11:14 pm
You are rotating the outer sleeve. You need to remove that first by sliding it off (first remove the O ring) and then the sleeve under that is the one you want to undo 🙂
Posted : 05/08/2019 11:25 pm
it took me 2 strap wrenches to get mine off!!!!
Posted : 06/08/2019 11:23 am
